on 24-05-2024 14:01
My wifi pod in bedroom has had several flashing lights and now it is making a hissing/buzzing, like a fan noise?
What should I do?
24-05-2024 14:15 - edited 24-05-2024 14:19
If you don't need it, I would unplug it and get a replacement asap. Otherwise just keep an eye on it in case it overheats or something.
See this thread - Solved: Noisy WiFi Pod - Virgin Media Community - 5168219
