on 07-09-2023 10:42
We just upgraded from the M350 package to the Gig1 Volt package and were sent a HUB 5. After activation, whilst being connected via Ethernet and with the Hub still in router mode I tried a Samknows RealSpeed test and was repeatably still getting 300-400Mbps down. Upload speed was however greatly improved to between 60-100Mbps.
The Hub config shows the config file as cmreg-vmdg660-bbt076-b and
Max Traffic Rate
1230000450 bps |
I also tried the HUB in modem mode with my UDM router connected via SFP to the 2.5Gbps port. The d/l speeds are still very underwhelming so I reported it via Whatsapp. The tech told me it Gig1 had not been activated and he had done so manually and to wait 4-5hours and reboot. I tried this several times but the d/l speed did not improve.
After checking the power levels and log I spotted a lot of Pre and Post RS Errors on all channels so I turned off the modem and remade/tightened all the connections to the Hub and V6 boxes. After another reboot the Pre and Post RS errors were clear and I was able to get 1.1Gb down and over 100Mbs up - happy days!
Unfortunately however this morning the Post RS Errors are back. Nothing "physical" has changed with the cabling overnight so I'm a bit puzzled. Am I right in assuming this needs an engineer call-out? What do you guys think is the best way to get this resolved?
1 | 331000000 | -7.4 | 40 | QAM 256 | 25 |
2 | 139000000 | -4 | 40 | QAM 256 | 1 |
3 | 147000000 | -4.3 | 40 | QAM 256 | 2 |
4 | 155000000 | -4.4 | 40 | QAM 256 | 3 |
5 | 163000000 | -4.5 | 40 | QAM 256 | 4 |
6 | 171000000 | -4.7 | 40 | QAM 256 | 5 |
7 | 179000000 | -4.8 | 40 | QAM 256 | 6 |
8 | 187000000 | -5 | 40 | QAM 256 | 7 |
9 | 195000000 | -5 | 40 | QAM 256 | 8 |
10 | 203000000 | -5.3 | 40 | QAM 256 | 9 |
11 | 211000000 | -5.4 | 40 | QAM 256 | 10 |
12 | 219000000 | -5.5 | 40 | QAM 256 | 11 |
13 | 227000000 | -5.9 | 40 | QAM 256 | 12 |
14 | 235000000 | -5.5 | 40 | QAM 256 | 13 |
15 | 243000000 | -5.5 | 40 | QAM 256 | 14 |
16 | 251000000 | -5.8 | 40 | QAM 256 | 15 |
17 | 259000000 | -5.7 | 40 | QAM 256 | 16 |
18 | 267000000 | -5.5 | 40 | QAM 256 | 17 |
19 | 275000000 | -5.9 | 40 | QAM 256 | 18 |
20 | 283000000 | -5.9 | 40 | QAM 256 | 19 |
21 | 291000000 | -6.1 | 40 | QAM 256 | 20 |
22 | 299000000 | -6.2 | 40 | QAM 256 | 21 |
23 | 307000000 | -6.4 | 40 | QAM 256 | 22 |
24 | 315000000 | -6.7 | 40 | QAM 256 | 23 |
25 | 323000000 | -7 | 40 | QAM 256 | 24 |
26 | 339000000 | -7.5 | 39 | QAM 256 | 26 |
27 | 347000000 | -7.7 | 40 | QAM 256 | 27 |
28 | 355000000 | -8 | 39 | QAM 256 | 28 |
29 | 363000000 | -7.9 | 39 | QAM 256 | 29 |
30 | 371000000 | -8.2 | 39 | QAM 256 | 30 |
31 | 379000000 | -8.3 | 39 | QAM 256 | 31 |
1 | Locked | 40 | 15221 | 45 |
2 | Locked | 40 | 13115 | 28094 |
3 | Locked | 40 | 33722 | 7799 |
4 | Locked | 40 | 28717 | 38081 |
5 | Locked | 40 | 38864 | 57012 |
6 | Locked | 40 | 10174 | 14876 |
7 | Locked | 40 | 3515 | 6648 |
8 | Locked | 40 | 5275 | 8729 |
9 | Locked | 40 | 46975 | 26803 |
10 | Locked | 40 | 36678 | 25513 |
11 | Locked | 40 | 35151 | 24021 |
12 | Locked | 40 | 34683 | 22602 |
13 | Locked | 40 | 37457 | 22290 |
14 | Locked | 40 | 37151 | 19159 |
15 | Locked | 40 | 34438 | 18980 |
16 | Locked | 40 | 32652 | 19185 |
17 | Locked | 40 | 37991 | 17444 |
18 | Locked | 40 | 44719 | 14553 |
19 | Locked | 40 | 43898 | 12030 |
20 | Locked | 40 | 49166 | 8780 |
21 | Locked | 40 | 60785 | 4247 |
22 | Locked | 40 | 61805 | 843 |
23 | Locked | 40 | 41084 | 180 |
24 | Locked | 40 | 19769 | 114 |
25 | Locked | 40 | 16582 | 77 |
26 | Locked | 39 | 14372 | 40 |
27 | Locked | 40 | 13553 | 27 |
28 | Locked | 39 | 12711 | 19 |
29 | Locked | 39 | 11992 | 9 |
30 | Locked | 39 | 11436 | 5 |
31 | Locked | 39 | 10753 | 4 |
Thanks in advance for any advice!
on 18-09-2023 10:46
Hi @Tom_W,
That time has now passed once again and the issue is still ongoing. What's the latest on the fault please?
Nobones
on 18-09-2023 17:50
Unfortunately your wasting your time, they'll just give you a few more dates, tell you it's resolved, ask you to reboot and when you tell them that didn't resolve the issue they'll act like they don't know what you're talking about and have you do the same again. Unfortunately you are now up a creek without a paddle.
on 21-09-2023 10:33
Hi Nobones,
Thanks for reaching back out, really sorry to see the SNR (Signal to Noise Ration) fault is still present, You might find that your Virgin Fibre, Voice and Virgin TV services are intermittent, with the picture freezing or disappearing now and then. We are sorry and our engineers are working hard to resolve this for you.
This now has an estimated fix date of 26/09/23 @ 10:00, the problem is first locating the connection which is causing the Noise on the Network, once locat5ed depending where it is we need permission from the local council to carry out the work, if it is under a busy road/ footpath then it will take longer as night work may be needed, apologies again for any inconvenience caused.
Paul.
on 26-09-2023 10:33
Thanks for the reply Paul.
It does not seem to be affecting my TV or phone service at all just the broadband speed. On the 19th I had thought the problem was fixed as I had 2 days of excellent speed and no Post RS errors on the modem.
Unfortunately that didn't last and the problem manifested itself again on the 22nd.
The estimated fix date/time has passed once again and the problem remains. Given what you said about the problem locating the fault and then possibily needing to apply for permission to carry out the work then I guess these estimated resolution fix date/times are simply placeholders and not accurate.
Is there any update on the work to locate the fault - has any progress been made on at least that?
Also, given that I am not getting getting the contracted "Minimum Guaranteed Download Speed" of 570Mbps for the Gig1 package is there a service credit or discount that now applies?
on 28-09-2023 12:50
Hi nobones 👋
Thanks for posting, and welcome to the Community Forums.
I'm sorry to hear you're continuing to experience some issues with your service. The fix times we provide are estimates and can change at short notice. It's not a case of them being inaccurate, but there can be various problems that arise during the initial repair that can cause this to change. I've taken a look on our side and can see that the known problem in your area is still being investigated. The details are below.
Fault Type: SNR (Signal-To-Noise) - You might find that your Virgin Fibre, Voice and Virgin TV services are intermittent, with the picture freezing or disappearing now and then.
Fault Reference: F010907317
Estimated Fix Time: 29 SEP 2023 10:00
In regard to compensation, this would only be provided in line with our Auto Compensation Scheme, which you can read more about here. You can also read more on our Speed Guarantee, which advises on lower than minimum speeds, here.
Our teams are working as quickly as possible to resolve this issue, and we're very sorry for any inconvenience caused. You can continue to track the fault by calling our Automated Service Checker on 📞 0800 561 0061.
Regards,
on 29-09-2023 16:03
Hi Reece_MH,
The 29th 10am has passed and the problem continues. What's the latest estimated fix time please?
on 01-10-2023 17:02
Hi @nobones
We're sorry it's not resolved. I have checked fault ticket F010907317 and the estimated fix date is the 4th at 10am.
Best wishes.
on 04-10-2023 13:20
Hi John_CS,
So the estimated fix date has passed once again and the issue remains. What's the latest this please? Has any progress at all been made towards a resolution?
on 06-10-2023 14:31
Hey nobones,
Sorry but the estimated fix time for the issues has been extended to the 10th of this month and a 10am time.
Kind Regards,
Steven_L
on 10-10-2023 10:46
Let me have a guess: fix time has now been extended to the 13th at 10am?
In all seriousness, if so this will be the 7th time an estimated fix time has come and gone and a new arbitrary date has been set. The original fault was raised on the 31st August so we're rapidly approaching the 6 week mark.
I understand the complexities that can be involved with tracking down and resolving an issue like this i.e obtaining wayleave permission etc but can you share whether any progress has been made towards this?
