Frequent connectivity dropout using GlobalProtect VPN
maxwellhill
I'm having a chronic issue with my work's VPN Global Protect but only while on my home network. Internet is generally pretty good around the house but my work laptop that uses GlobalProtect drops every 10-15 minutes, whether I am on Wifi or ethernet. It seems to be the upload that is most affected as sometimes I will freeze and lose audio on a video call but still be able to watch and hear teammates asking if i'm still there
It all works without issue on other networks so there's obviously some conflict with my home Virgin Media setup. I have tried turning off for 15 minutes, performed a hard reset etc all the classics to no avail.
1 ACCEPTED SOLUTION
Accepted Solutions
Mystery solved... it was actually another device on the network that was playing up. I reset it and all is well
25 REPLIES 25
maxwellhill
Router status
331000000
Locked
Ranged Upstream Channel (Hz)
36600044
Locked
Provisioning State
Online
13310000002.538256 qam25
21390000002.536256 qam1
31470000002.736256 qam2
4155000000337256 qam3
51630000002.937256 qam4
61710000002.937256 qam5
7179000000337256 qam6
81870000002.937256 qam7
91950000002.737256 qam8
102030000002.937256 qam9
112110000003.237256 qam10
122190000003.538256 qam11
13227000000338256 qam12
142350000003.238256 qam13
152430000002.938256 qam14
162510000002.538256 qam15
172590000002.238256 qam16
183390000002.238256 qam26
19347000000238256 qam27
203550000002.438256 qam28
213630000002.238256 qam29
223710000002.238256 qam30
233790000001.738256 qam31
243870000001.738256 qam32
1Locked38.9880
2Locked36.34360
3Locked36.63960
4Locked37.33750
5Locked37.33370
6Locked37.33390
7Locked37.32930
8Locked37.63060
9Locked37.63190
10Locked37.63030
11Locked37.32770
12Locked38.62370
13Locked38.62510
14Locked38.92270
15Locked38.62110
16Locked38.92020
17Locked38.91800
18Locked38.6900
19Locked38.91130
20Locked38.6960
21Locked38.9860
22Locked38.91070
23Locked38.91090
24Locked38.91160
13660004446.8512064 qam9
23010000047512016 qam10
34310000047.3512064 qam8
44960000047.5512064 qam7
52360000046.5512064 qam11
1ATDMA0020
2ATDMA0010
3ATDMA0000
4ATDMA0000
5ATDMA0000
General Configuration
Network access
Allowed
Maximum Number of CPEs
1
Baseline Privacy
Enabled
DOCSIS Mode
Docsis30
Config file
cmreg-vmdg505-bbt057-b.cm
SFID18200
Max Traffic Rate143750047
Max Traffic Burst42600
Min Traffic Rate0
Primary Upstream Service Flow
SFID18199
Max Traffic Rate22000047
Min Traffic Rate0
Max Concatenated Burst42600
Scheduling TypeBestEffort
Log
10/09/2024 10:48:40noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
10/09/2024 09:10:10criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
09/09/2024 19:50:59noticeLAN login Success;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
01/01/1970 00:01:40criticalNo Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
Members of the forum frequently report call quality issues with MS Teams.
Other conference call platforms see very few reported issues.
Please share the details from the Upstream and Downstream tabs,
these figures give us an insight into the quality of your connection to the VM Network.
maxwellhill
21710000002.737256 qam5
3179000000337256 qam6
41870000002.937256 qam7
51950000002.737256 qam8
62030000002.737256 qam9
72110000003.237256 qam10
82190000003.538256 qam11
9227000000338256 qam12
102350000003.238256 qam13
112430000002.938256 qam14
122510000002.538256 qam15
132590000002.238256 qam16
142670000002.738256 qam17
152750000002.538256 qam18
162830000002.938256 qam19
172910000002.738256 qam20
18299000000338256 qam21
193070000002.938256 qam22
203150000002.538256 qam23
213230000002.538256 qam24
223390000002.238256 qam26
23347000000238256 qam27
243550000002.438256 qam28
1Locked38.650
2Locked37.3100
3Locked37.6210
4Locked37.6210
5Locked37.6220
6Locked37.680
7Locked37.6110
8Locked38.6110
9Locked38.6100
10Locked38.6130
11Locked38.6120
12Locked38.6100
13Locked38.630
14Locked38.970
15Locked38.690
16Locked38.9110
17Locked38.9100
18Locked38.6110
19Locked38.990
20Locked38.9100
21Locked38.970
22Locked38.650
23Locked38.940
24Locked38.980
maxwellhill
13660027346.8512064 qam9
23010000046.8512032 qam10
34960027347.5512064 qam7
42360000046.8512032 qam11
54310027847.3512064 qam8
3ATDMA0000
4ATDMA0000
5ATDMA0000
maxwellhill
Thanks for responding. I've only just rebooted the hub so this may not be so helpful. There are generally T3 timeouts
Teams is definitely an issue but I have other connections that are disrupted like DB queries which take longer than 3 minutes to return results
Lets see the 2 tables of data for the downstream channels
I do not work for VM. My services: HD TV on VIP (+ Sky Sports & Movies & TNT sport), x3 V6 boxes (1 wired, 2 on WiFi), Hub5 in modem mode with Apple Airport Extreme Router +2 Airport Express's & TP-Link Archer C64 WAP. On Volt 350Mbps, Talk Anytime Phone, x2 Mobile SIM only iPhones.
