Jhmzpwer's avatar
Jhmzpwer
Frequent connection drops
I am experiencing an issue with my hub 3 where my internet connection frequently drops. When this occurs, the power light begins to flash green, the WiFi light then shows solid green and then the internet light flashes green. I lose all internet connectivity when this happens. Eventually, the power light turns white, the other lights disappear, and the connection is (temporarily) restored.
This has been happening several times each hour and is impacting devices on both wireless and wired connections.
I have already done the following:
- Restarted the hub several times
- Checked for any issues in my area & had Virgin check the status of my equipment (apparently no problems)
- Performed a hard reset (pinhole) twice
- Unplugged / replugged and checked all wires
I will add the contents of my hub status page below.
Please could somebody assist?
  • Cable Modem Status
    Item
    Status
    Comments
    331000000
    Locked
    Ranged Upstream Channel (Hz)
    43100036
    Locked
    Provisioning State
    Online
  • Downstream bonded channels
    Channel
    Frequency (Hz)
    Power (dBmV)
    SNR (dB)
    Modulation
    Channel ID
    1
    331000000
    4.5
    40
    256 qam
    25
    2
    171000000
    4.8
    40
    256 qam
    5
    3
    179000000
    4.8
    40
    256 qam
    6
    4
    187000000
    4.8
    40
    256 qam
    7
    5
    195000000
    4.6
    40
    256 qam
    8
    6
    203000000
    4.5
    40
    256 qam
    9
    7
    211000000
    4.5
    40
    256 qam
    10
    8
    219000000
    4.4
    40
    256 qam
    11
    9
    227000000
    3.9
    40
    256 qam
    12
    10
    243000000
    3.7
    40
    256 qam
    14
    11
    251000000
    3.2
    40
    256 qam
    15
    12
    275000000
    3.5
    40
    256 qam
    18
    13
    283000000
    3.7
    40
    256 qam
    19
    14
    299000000
    3.7
    40
    256 qam
    21
    15
    307000000
    4
    40
    256 qam
    22
    16
    315000000
    4.6
    40
    256 qam
    23
    17
    339000000
    4.8
    40
    256 qam
    26
    18
    347000000
    5
    40
    256 qam
    27
    19
    371000000
    4.4
    40
    256 qam
    30
    20
    379000000
    4.5
    40
    256 qam
    31
    21
    387000000
    4.1
    40
    256 qam
    32
    22
    403000000
    3.5
    40
    256 qam
    34
    23
    411000000
    3.9
    40
    256 qam
    35
    24
    419000000
    3.7
    40
    256 qam
    36
    Channel
    Locked Status
    RxMER (dB)
    Pre RS Errors
    Post RS Errors
    1
    Locked
    40.3
    0
    0
    2
    Locked
    40.3
    5
    0
    3
    Locked
    40.3
    0
    0
    4
    Locked
    40.3
    3
    0
    5
    Locked
    40.3
    4
    0
    6
    Locked
    40.3
    3
    0
    7
    Locked
    40.9
    5
    0
    8
    Locked
    40.9
    6
    0
    9
    Locked
    40.3
    0
    0
    10
    Locked
    40.9
    7
    0
    11
    Locked
    40.9
    0
    0
    12
    Locked
    40.3
    4
    0
    13
    Locked
    40.9
    5
    0
    14
    Locked
    40.3
    0
    0
    15
    Locked
    40.9
    4
    0
    16
    Locked
    40.9
    5
    0
    17
    Locked
    40.9
    6
    0
    18
    Locked
    40.3
    5
    0
    19
    Locked
    40.3
    0
    0
    20
    Locked
    40.3
    11
    0
    21
    Locked
    40.9
    6
    0
    22
    Locked
    40.9
    0
    0
    23
    Locked
    40.3
    6
    0
    24
    Locked
    40.3
    5
    0
  • Upstream bonded channels
    Channel
    Frequency (Hz)
    Power (dBmV)
    Symbol Rate (ksps)
    Modulation
    Channel ID
    1
    43100036
    41.5
    5120
    64 qam
    2
    2
    23599961
    41.5
    5120
    64 qam
    5
    3
    30100041
    41.5
    5120
    64 qam
    4
    4
    36599996
    41.5
    5120
    64 qam
    3
    5
    49600024
    41.5
    5120
    64 qam
    1
    Channel
    Channel Type
    T1 Timeouts
    T2 Timeouts
    T3 Timeouts
    T4 Timeouts
    1
    ATDMA
    0
    0
    0
    0
    2
    ATDMA
    0
    0
    0
    0
    3
    ATDMA
    0
    0
    0
    0
    4
    ATDMA
    0
    0
    0
    0
    5
    ATDMA
    0
    0
    0
    0
  • General Configuration
    Network access
    Allowed
    Maximum Number of CPEs
    1
    Baseline Privacy
    Enabled
    DOCSIS Mode
    Docsis30
    Config file
    oA,.iyewrkldJKDHSUBsgvca6
    SFID
    16330
    Max Traffic Rate
    143750047
    Max Traffic Burst
    42600
    Min Traffic Rate
    0
    Primary Upstream Service Flow
    SFID
    16329
    Max Traffic Rate
    22000047
    Max Traffic Burst
    42600
    Min Traffic Rate
    0
    Max Concatenated Burst
    42600
    Scheduling Type
    BestEffort
  • Network Log
    Time
    Priority
    Description
    11/03/2024 12:37:42
    Error
    TCS Fail on all Upstream Channels;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    11/03/2024 12:37:42
    critical
    16 consecutive T3 timeouts while trying to range on upstream channel 1;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    11/03/2024 12:37:42
    critical
    Ranging Request Retries exhausted;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    11/03/2024 12:37:39
    critical
    16 consecutive T3 timeouts while trying to range on upstream channel 4;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    11/03/2024 12:37:39
    critical
    11/03/2024 12:37:38
    critical
    11/03/2024 12:37:36
    critical
    16 consecutive T3 timeouts while trying to range on upstream channel 2;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    11/03/2024 12:37:36
    critical
    11/03/2024 12:37:29
    critical
    11/03/2024 12:37:28
    critical
    16 consecutive T3 timeouts while trying to range on upstream channel 3;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    11/03/2024 12:37:28
    critical
    11/03/2024 12:37:24
    critical
    11/03/2024 12:37:22
    critical
    16 consecutive T3 timeouts while trying to range on upstream channel 5;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.0;
    11/03/2024 12:37:22
    critical
    11/03/2024 12:36:2
    critical
    11/03/2024 12:23:56
    Error
    11/03/2024 12:23:56
    critical
    11/03/2024 12:23:56
    critical
    11/03/2024 12:23:47
    critical
    11/03/2024 12:23:47
    critical
  • Daniel_Et's avatar
    Daniel_Et
    Hi Jhmzpwer, thank you for your posts.
    We're sorry to hear about the issue you're experiencing 😔
    In order to discuss this with you further, we'll send you a private message on here. Look out for the envelope in the top right-hand corner.
    Regards,
    Daniel
