Errors - power levels
javedsaleem
I recently renewed my Contract......and now I have lots of errors
3.0 Downstream channels
1 306000000 5.9 41 QAM 256 22
2 138000000 6.9 42 QAM 256 1
3 146000000 6.9 42 QAM 256 2
4 154000000 7 42 QAM 256 3
5 162000000 7 42 QAM 256 4
6 170000000 6.9 42 QAM 256 5
7 178000000 6.8 42 QAM 256 6
8 186000000 6.7 42 QAM 256 7
9 194000000 6.9 42 QAM 256 8
10 202000000 6.8 42 QAM 256 9
11 210000000 7 42 QAM 256 10
12 218000000 6.9 42 QAM 256 11
13 226000000 6.7 42 QAM 256 12
14 234000000 6.4 42 QAM 256 13
15 242000000 6.3 42 QAM 256 14
16 250000000 6.2 42 QAM 256 15
17 258000000 6.2 42 QAM 256 16
18 266000000 6.2 42 QAM 256 17
19 274000000 6.2 42 QAM 256 18
20 282000000 6.2 41 QAM 256 19
21 290000000 6.1 41 QAM 256 20
22 298000000 5.9 41 QAM 256 21
23 314000000 5.9 41 QAM 256 23
24 322000000 5.7 41 QAM 256 24
25 330000000 5.5 41 QAM 256 25
26 338000000 5.5 40 QAM 256 26
27 346000000 5.5 41 QAM 256 27
28 354000000 5.4 41 QAM 256 28
29 362000000 5.5 41 QAM 256 29
30 370000000 5.6 41 QAM 256 30
31 378000000 5.8 41 QAM 256 31
32 386000000 5.8 41 QAM 256 32
1 Locked 41 9351 7399
2 Locked 42 2446 8508
3 Locked 42 10507 26013
4 Locked 42 961 2221
5 Locked 42 1117 4834
6 Locked 42 25 119
7 Locked 42 1181 4884
8 Locked 42 6385 23194
9 Locked 42 6357 24328
10 Locked 42 6572 25753
11 Locked 42 13048 37499
12 Locked 42 10951 21499
13 Locked 42 10819 20651
14 Locked 42 12389 37541
15 Locked 42 1166 4616
16 Locked 42 14780 48317
17 Locked 42 7334 15709
18 Locked 42 10973 16589
19 Locked 42 10142 20093
20 Locked 41 6462 19074
21 Locked 41 13872 35589
22 Locked 41 12395 19513
23 Locked 41 9651 11404
24 Locked 41 8189 20916
25 Locked 41 2063 8991
26 Locked 40 7077 14142
27 Locked 41 11008 8600
28 Locked 41 9103 4289
29 Locked 41 9534 8082
30 Locked 41 7714 10213
31 Locked 41 10524 11998
32 Locked 41 10694 11430
3.1 Downstream channels
159 94 4K 1840 QAM 4096 1108
159 Locked 41 5.4 555941319 0
24 REPLIES 24
Thank you @javedsaleem we have double checked and currently there are no issues raised with our team for any high utilisation in the area.
Are you able to confirm if this is happening across WiFi or wired connection so we can advise further?
Both
Is it possible, that if the Power (dBmV) is too high, that there could be noise on the line and that maybe moving the connection down at the Street Box, to a lower power level, may bring about improvement.
I don't think it has anything to do with utilisation.
Hi javedsaleem,
Thanks for coming back to us on this one.
Both the upstream and downstream power levels on your cable should be at an optimal level for your Hub to function as it should. When the levels are too low or too high, it can lower the speed/throughput of your internet connections. You might also encounter repeated disconnections, high network latency, buffering and slow downloading and uploading speeds as well. Due to this we would look at adjusting the levels to your hub by adding an attenuator if it's needed. This is usually done by an engineer.
Checking your levels here, your upstream ones are a little high and your downstream levels are a little low. Not overly, but enough that it may cause you some issues. We won't be able to fix this remotely so I would like to arrange for an engineer to come to take a look at this for you.
I just need to confirm the address to ensure we are booking the visit on the correct account. I have sent you a direct message to allow us to do this with you in a private space. If you are using a PC/Laptop then you can just click on the little ✉ at the top right-hand side of the page to access your inbox. If you are on a mobile/tablet device then instead click on the little circle icon in the top right then select 'Messages'. 😊
Kath_F
Hi @javedsaleem,
Thanks for coming back to via private message to confirm your information. 🤩
I have booked you in for the next available appointment. To view this please sign in to My Virgin Media here 👉 My VM. Once you log in scroll down to Orders & appointments then click on View your orders. Please note it can take up to 24 hours to show but you should also receive a text message with the details. You can also view this in the My VM app. If you have any issues with accessing your account or unable to see your visit, please do let us know and we’ll pop you a message to pass data protection and confirm the appointment details.
Just to confirm, there will be no charge for this visit unless:
  • ➡ The technician diagnoses the faults as not being caused by our network/equipment
  • ➡ The technician discovers that the fault or problem relates to your equipment
  • ➡ The technician discovers that the fault or problem relates to any system that we are not responsible for
  • ➡ The technician will confirm during their visit if any of these instances apply, and if so, a £25 charge will be applied to your account.
Please ensure there is someone over the age of 18 present at the time of the visit. If you need to change or cancel your appointment you can do this online or via the MyVM app by 4pm the day before the appointment. If you do miss an agreed appointment for any reason, a £25 missed appointment charge will be applied to your account on the day of the appointment.
Let us know how the appointment goes. 😊
Take care.
Kath_F
