Hi javedsaleem,
Thanks for coming back to us on this one.
Both the upstream and downstream power levels on your cable should be at an optimal level for your Hub to function as it should. When the levels are too low or too high, it can lower the speed/throughput of your internet connections. You might also encounter repeated disconnections, high network latency, buffering and slow downloading and uploading speeds as well. Due to this we would look at adjusting the levels to your hub by adding an attenuator if it's needed. This is usually done by an engineer.
Checking your levels here, your upstream ones are a little high and your downstream levels are a little low. Not overly, but enough that it may cause you some issues. We won't be able to fix this remotely so I would like to arrange for an engineer to come to take a look at this for you.
I just need to confirm the address to ensure we are booking the visit on the correct account. I have sent you a direct message to allow us to do this with you in a private space. If you are using a PC/Laptop then you can just click on the little ✉ at the top right-hand side of the page to access your inbox. If you are on a mobile/tablet device then instead click on the little circle icon in the top right then select 'Messages'. 😊
