Does the M250 WiFi hub have Ethernet ports?
Elitegamer010
Just joined
Does the "Virgin Media WiFi Hub" (is that just the name of Virgin's router or is it a different thing?) that I would get from the "M250 Fibre Broadband" deal have ports for Ethernet cables? I want to be able to connect an Ethernet cable straight between the WiFi hub and my PC. My PC is connected to my current, non-Virgin router in this way.
If it matters, my Ethernet cable is category 5E.
Is there anywhere I could find labelled photos, diagrams or anything like that of the WiFI Hub/router, so I'll know exactly what I would get?
3 REPLIES 3
Cardiffman282
Problem sorter
4 ethernet ports on the Hub 3.
See https://www.virginmedia.com/broadband/existing-customer-deals/hub
Cancel VM here
Complain to VM
here
Demand compensation from VM here
Demand your call recordings here
Monitor the state of your VM connection here
jaberwok
Virgin's Hub 5 has four ethernet ports plus two ports for telephone connections; earlier hubs (routers) have four ethernet ports
How else would you get your speed! yes all hubs will have Ethernet ports
