Does iPad 10 (wifi 6) work with Hub 3?
spinduck
As per my subject line, could anyone confirm whether a Hub 3 would support an Ipad 10th Generation (2022) which has wifi 6?
Thank-you
1 ACCEPTED SOLUTION
Accepted Solutions
Yes that combination works fine.
We have a VM Hub 3 working well with a range of current Apple gear.
The setting that is critical on the Hub 3 is to have Wi-Fi Security set to WPA2-PSK
this will ensure a fuss free connection with Apple kt.
3 REPLIES 3
Thank you, Client62.
Yes it will work fine, but only in WiFi mode 5.
