spinduck's avatar
spinduck
9 months ago
Does iPad 10 (wifi 6) work with Hub 3?
As per my subject line, could anyone confirm whether a Hub 3 would support an Ipad 10th Generation (2022) which has wifi 6? Thank-you
    9 months ago
    Yes that combination works fine.
    We have a VM Hub 3 working well with a range of current Apple gear.
    The setting that is critical on the Hub 3 is to have Wi-Fi Security set to WPA2-PSK
    this will ensure a fuss free connection with Apple kt.
