Silentdav's avatar
Silentdav
Disabling wifi and using Ethernet .
Hi, I'm not technical at all so apologies if is obvious / doesn't make sense!
So, I want to disable wifi on my hub 3.0 router. I want to only use Ethernet cables to access the internet (on 2 smart TVs and a games console essentially) - I'm living with someone who believes wifi is evil! 😆
I logged in to the router (using an Ethernet cable and laptop) and managed to disable the Wi-Fi but when I connected the other devices by Ethernet cables to the ports at the back of the router, only the cable linked to my laptop was working. I went into the settings on the TV but they were suggesting that no Ethernet cables were detected. I tried different ports with no luck.
The router was not in modem mode. So, I guess I'm asking whether it's possible to do what I want to do and if so, what am I doing wrong?
Thanks for your help!
  • Tudor's avatar
    Try a pin-hole reset of the hub and then disable WiFi again.
  • nodrogd's avatar
    nodrogd
    Make sure you are just disabling Wi-Fi & not putting the hub into modem mode. You need it in router mode to use all the sockets.
  • Thanks for the replies. Will try the reset tonight after work!
    I'd change the SSID and the Password and just say the job is done.
    An SSID like BTxxxxxx or SKYxxxxxx might be enough to put the person off the scent.
    Especially as their Phone / Laptop should have Wi-Fi disabled.
    Our Hub 3 is in Router mode and all 4 network ports work.
    To disable the Wi-Fi on both bands :
    Hub 3 menu:   Advanced settings >> Wireless >> Wireless signal
          Disable Channel Optimization ( to unlock the Wi-Fi settings )
          Disable 2.4 GHz
          Disable 5 GHz
          Click Apply changes
    Allow the Hub 3 a couple of minutes to stop its Wi-Fi services.
  • Roger_Gooner's avatar
    Roger_Gooner
    If you disable WiFi how are you supposed to get a WiFi connection for your mobile devices? I suggest simply disabling the SSID broadcast and secretly doing WiFi connections.
    • asim18's avatar
      asim18
      Rising star
      You can use USB-C Ethernet adapters. Most modern android phones support USB Ethernet.
      I also like to use as little WiFi as possible. Especially when my phone is in my hands or my laptop is on my nads.
  • jpeg1's avatar
    jpeg1
    Your phone is regularly talking to the mobile network, even when you have an ethernet connection. It has to so that the network knows where it is for incoming calls. And it transmits at many times the power of WiFi.
    There is no technical solution to an emotional problem.
    • asim18's avatar
      asim18
      Rising star
      I don't believe human EMR exposure research is a psychiatrist's or psychologist's area of medicine or research, I believe it's biological or physiological issue. You won't get a psychologist studying the effects of EMR on biological tissue or psysiological systems. This is the domain of a biologist.
      At the fundamental level, It's been proven that EMR damages biological cells, enough to cause cell apoptosis. Therefore at the most basic level, RF will be damaging and killing my skin cells, at the very least. I would rather not kill my skin cells even if they are easily repaired.
      If you want to dig deeper, RF exposure actually causes biochemical and neurochemical changes.
      Yes humans have a thicker skull than rats and we have more massive brains, but almost all human bio research is undertaken on rats and I would rather not take any chances.
      Quotation source https://pubmed.ncbi.nlm.nih.gov/11948603/ -- "This work indicates that neurochemical modification of the hippocampal cholinergic system can be observed during and after an exposure to low intensity RF."
      Quotation source https://pubmed.ncbi.nlm.nih.gov/29332300/ -- "Long term exposure to cell phone frequencies (900 and 1800 MHz) induces apoptosis, mitochondrial oxidative stress and TRPV1 channel activation in the hippocampus and dorsal root ganglion of rats."
      Quotation source https://www.ncbi.nlm.nih.gov/pmc/articles/PMC8415840/  -- "These data suggest that EMR can lead to a decrease in excitatory amino acid neurotransmitters in the hippocampus, which may affect the excitatory-inhibitory balance of neurons, thus causing a decline in learning and memory ability." -- "Following microwave exposure, rats exhibited a significant decrease in learning and memory ability at 7 days"
      I think there's definitely a correlation too, the amount of human zombies is increasing drastically in recent times.
  • jpeg1's avatar
    jpeg1
    I'm not arguing your belief, just that if you want to avoid RF exposure you will not be using a mobile phone at all, because it transmits intermittently while it is switched on.  So discussion of connection methods is irrelevant. You need to avoid the phone altogether.
    • asim18's avatar
      asim18
      Rising star
      I agree, unfortunately it's impossible to 'completely avoid' RF exposure. But it's definitely possible to 'limit' RF exposure.
      If my phone has a WiFi and 5g transiever, I can turn off the wifi and reduce the amount of RF im being pummelled by. If I am not expecting any calls I can even disable my sim card to further reduce exposure. Yes RF is difficult to completely remove from modern life, but if I can reduce it by even 50% then that's a positive thing to me personally.
      Laptop is even better, I don't have to worry about my WiFi chip being millimeteres away from my......... And as a bonus; Ethernet is 5 times faster than my WiFi.
    Oh la la ... Ladies you have entered the ...
