- jbrennandVery Insightful Person
Is it a general fault or one specific to you?
Look in 2 places
1) Try the “check service,”Area status webpage (https://www.virginmedia.com/help/service-status)
2) Then also Try the “free & automated” Service Status number - 0800 561 0061 - which usually gives the most up to date info. and tells you of more local issues and fix estimates, down to street cab/ postcode level.
The "compensation "timer" can also be started on this number if appropriate.
Faults may not be listed on the Area Status web page. Areas are not Geographic” they are "legacy billing" areas) and as such that usually only covers faults affecting 1000’s of customers across the country. So 0800 may give you more info, on local issues - but even that wont cover problems affecting just a few customers - or just you. If nothing shows on there, try calling it in as a fault - free on 150 (VM line) or 0345 454 1111 others (national rate). See what they say when they test your connection. If they say it’s a known fault, get a fault reference number.
Or, a VM person should pick this thread up and be able to help but it can take a few days - Robert_P
Hello safc_01203
Sorry to hear of the connection issues experienced, we understand the frustration and you raising this via the forums for support.
It's been a few days since your post, are you still experiencing issues with the connection? Have you tried the steps offer by jbrennand? Let us know.
Related Content
- 31 days ago
- 2 years ago
- 3 years ago
- 2 years ago
