on 28-05-2024 16:15
Good day,
We had VM for a while now but last few months it keeps annoying me. So the situation is that the Internet just going for 30-60 seconds and then coming back. It is no a Wi-Fi and router (Hub 5) still shows white, steady light.
Every time I do testes on VM website, it comes back hat i need to reboot the router, as there is nothing wrong.
We had VM technician coming few times, replacing socket, cable in house (from the socket to the router), replacing router itself. I then just gave up and got 5G as a backup....
Could someone have a quick look at the below logs and let me know if there is anything 'obvious'? I just do not want another technical coming and saying 'nothing is wrong', etc..
Thank you in advance
Time | Priority | Description |
28-05-2024 16:11:40 | notice | GUI Login Status - Login Success from LAN interface |
28-05-2024 16:10:12 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=XXXXXXX;CMTS-MAC=XXXXXXX;CM-QOS=1.1;CM-VER=3.1; |
28-05-2024 14:34:54 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=XXXXXXX;CMTS-MAC=XXXXXXX;CM-QOS=1.1;CM-VER=3.1; |
28-05-2024 14:29:51 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=XXXXXXX;CMTS-MAC=XXXXXXX;CM-QOS=1.1;CM-VER=3.1; |
28-05-2024 14:19:59 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=XXXXXXX;CMTS-MAC=XXXXXXX;CM-QOS=1.1;CM-VER=3.1; |
28-05-2024 14:14:56 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=XXXXXXX;CMTS-MAC=XXXXXXX;CM-QOS=1.1;CM-VER=3.1; |
28-05-2024 14:02:51 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=XXXXXXX;CMTS-MAC=XXXXXXX;CM-QOS=1.1;CM-VER=3.1; |
28-05-2024 14:02:51 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=XXXXXXX;CMTS-MAC=XXXXXXX;CM-QOS=1.1;CM-VER=3.1; |
28-05-2024 14:02:51 | warning | Dynamic Range Window violation |
28-05-2024 14:02:50 | warning | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=XXXXXXX;CMTS-MAC=XXXXXXX;CM-QOS=1.1;CM-VER=3.1; |
28-05-2024 14:02:50 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=XXXXXXX;CMTS-MAC=XXXXXXX;CM-QOS=1.1;CM-VER=3.1; |
28-05-2024 14:02:49 | warning | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=XXXXXXX;CMTS-MAC=XXXXXXX;CM-QOS=1.1;CM-VER=3.1; |
28-05-2024 14:02:49 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=XXXXXXX;CMTS-MAC=XXXXXXX;CM-QOS=1.1;CM-VER=3.1; |
28-05-2024 14:01:50 | warning | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=XXXXXXX;CMTS-MAC=XXXXXXX;CM-QOS=1.1;CM-VER=3.1; |
28-05-2024 14:01:43 | notice | CM-STATUS message sent. Event Type Code: 24; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=XXXXXXX;CMTS-MAC=XXXXXXX;CM-QOS=1.1;CM-VER=3.1; |
28-05-2024 14:01:05 | warning | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=XXXXXXX;CMTS-MAC=XXXXXXX;CM-QOS=1.1;CM-VER=3.1; |
28-05-2024 14:01:03 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=XXXXXXX;CMTS-MAC=XXXXXXX;CM-QOS=1.1;CM-VER=3.1; |
28-05-2024 13:59:54 | warning | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=XXXXXXX;CMTS-MAC=XXXXXXX;CM-QOS=1.1;CM-VER=3.1; |
28-05-2024 13:57:57 | notice | CM-STATUS message sent. Event Type Code: 16; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=XXXXXXX;CMTS-MAC=XXXXXXX;CM-QOS=1.1;CM-VER=3.1; |
28-05-2024 13:56:01 | warning | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=XXXXXXX;CMTS-MAC=XXXXXXX;CM-QOS=1.1;CM-VER=3.1; |
28-05-2024 13:56:00 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=XXXXXXX;CMTS-MAC=XXXXXXX;CM-QOS=1.1;CM-VER=3.1; |
28-05-2024 13:04:23 | notice | CM-STATUS message sent. Event Type Code: 24; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=XXXXXXX;CMTS-MAC=XXXXXXX;CM-QOS=1.1;CM-VER=3.1; |
28-05-2024 13:01:53 | warning | Dynamic Range Window violation |
28-05-2024 13:01:53 | warning | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW;CM-MAC=XXXXXXX;CMTS-MAC=XXXXXXX;CM-QOS=1.1;CM-VER=3.1; |
28-05-2024 13:01:52 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=XXXXXXX;CMTS-MAC=XXXXXXX;CM-QOS=1.1;CM-VER=3.1; |
28-05-2024 13:01:50 | warning | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=XXXXXXX;CMTS-MAC=XXXXXXX;CM-QOS=1.1;CM-VER=3.1; |
28-05-2024 13:01:50 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=XXXXXXX;CMTS-MAC=XXXXXXX;CM-QOS=1.1;CM-VER=3.1; |
28-05-2024 13:01:41 | notice | CM-STATUS message sent. Event Type Code: 16; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 2 3.;CM-MAC=XXXXXXX;CMTS-MAC=XXXXXXX;CM-QOS=1.1;CM-VER=3.1; |
28-05-2024 13:01:41 | error | DBC-ACK not received;CM-MAC=XXXXXXX;CMTS-MAC=XXXXXXX;CM-QOS=1.1;CM-VER=3.1; |
28-05-2024 13:01:38 | notice | US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=XXXXXXX;CMTS-MAC=XXXXXXX;CM-QOS=1.1;CM-VER=3.1; |
28-05-2024 13:00:09 | warning | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=XXXXXXX;CMTS-MAC=XXXXXXX;CM-QOS=1.1;CM-VER=3.1; |
28-05-2024 13:00:01 | critical | Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=XXXXXXX;CMTS-MAC=XXXXXXX;CM-QOS=1.1;CM-VER=3.1; |
28-05-2024 12:56:39 | notice | CM-STATUS message sent. Event Type Code: 16; Chan ID: 33; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 3.;CM-MAC=XXXXXXX;CMTS-MAC=XXXXXXX;CM-QOS=1.1;CM-VER=3.1; |
27-05-2024 11:11:43 | notice | GUI Login Status - Login Success from LAN interfa |
Answered! Go to Answer
on 30-05-2024 08:28
The Post Rs aka Uncorrectable errors across all Downstream channels and Upstream T3 Timeouts would be my concern ... especially if the numbers are still rising.
3.0 Downstream channels
1 | Locked | 41 | 15030 | 7360 |
2 | Locked | 40 | 55055 | 4721 |
3 | Locked | 40 | 75232 | 17398 |
4 | Locked | 41 | 89922 | 18841 |
5 | Locked | 41 | 170115 | 32456 |
6 | Locked | 41 | 149061 | 27806 |
7 | Locked | 41 | 59018 | 9879 |
8 | Locked | 41 | 18710 | 7553 |
9 | Locked | 41 | 13568 | 4667 |
3.1 Downstream channels
33 | Locked | 42 | 6.1 | 803862190 | 31543 |
3.0 Upstream channels
0 | ATDMA | 0 | 0 | 3 | 0 |
1 | ATDMA | 0 | 0 | 30 | 0 |
2 | ATDMA | 0 | 0 | 138 | 0 |
3 | ATDMA | 0 | 0 | 39 | 0 |
4 | ATDMA | 0 | 0 | 154 | 0 |
on 29-05-2024 11:25
The log tab is a lot less enlightening that one might wish. Could you share the information from the Upstream and the Downstream tabs so we get to see any issues in the signal power levels / errors / modulation modes.
on 29-05-2024 19:01
Thank you for the reply.
1 | 331000000 | 6.5 | 41 | QAM 256 | 25 |
2 | 147000000 | 5.8 | 40 | QAM 256 | 2 |
3 | 155000000 | 6.2 | 40 | QAM 256 | 3 |
4 | 163000000 | 6.3 | 41 | QAM 256 | 4 |
5 | 171000000 | 6.5 | 41 | QAM 256 | 5 |
6 | 179000000 | 6.9 | 41 | QAM 256 | 6 |
7 | 187000000 | 7.2 | 41 | QAM 256 | 7 |
8 | 195000000 | 7.4 | 41 | QAM 256 | 8 |
9 | 203000000 | 7.6 | 41 | QAM 256 | 9 |
10 | 211000000 | 7.9 | 41 | QAM 256 | 10 |
11 | 219000000 | 7.5 | 41 | QAM 256 | 11 |
12 | 227000000 | 7.2 | 41 | QAM 256 | 12 |
13 | 235000000 | 6.9 | 41 | QAM 256 | 13 |
14 | 243000000 | 6.9 | 41 | QAM 256 | 14 |
15 | 251000000 | 6.6 | 41 | QAM 256 | 15 |
16 | 259000000 | 6.4 | 41 | QAM 256 | 16 |
17 | 267000000 | 6.4 | 41 | QAM 256 | 17 |
18 | 275000000 | 6.3 | 41 | QAM 256 | 18 |
19 | 283000000 | 6.3 | 41 | QAM 256 | 19 |
20 | 291000000 | 6.5 | 41 | QAM 256 | 20 |
21 | 299000000 | 6.6 | 41 | QAM 256 | 21 |
22 | 307000000 | 6.4 | 41 | QAM 256 | 22 |
23 | 315000000 | 6.3 | 41 | QAM 256 | 23 |
24 | 323000000 | 6.3 | 41 | QAM 256 | 24 |
25 | 339000000 | 6.4 | 41 | QAM 256 | 26 |
26 | 347000000 | 6.6 | 42 | QAM 256 | 27 |
27 | 355000000 | 6.8 | 42 | QAM 256 | 28 |
28 | 363000000 | 6.8 | 42 | QAM 256 | 29 |
29 | 371000000 | 6.8 | 42 | QAM 256 | 30 |
30 | 379000000 | 6.9 | 42 | QAM 256 | 31 |
31 | 387000000 | 7 | 42 | QAM 256 | 32 |
10 | Locked | 41 | 7891 | 4383 |
11 | Locked | 41 | 5440 | 3331 |
12 | Locked | 41 | 5577 | 3371 |
13 | Locked | 41 | 12721 | 4170 |
14 | Locked | 41 | 12136 | 4155 |
15 | Locked | 41 | 20984 | 4926 |
16 | Locked | 41 | 19762 | 4631 |
17 | Locked | 41 | 10305 | 4662 |
18 | Locked | 41 | 18970 | 5893 |
19 | Locked | 41 | 13854 | 7769 |
20 | Locked | 41 | 19517 | 6963 |
21 | Locked | 41 | 19783 | 7541 |
22 | Locked | 41 | 18847 | 7812 |
23 | Locked | 41 | 15892 | 6109 |
24 | Locked | 41 | 14220 | 5940 |
25 | Locked | 41 | 12908 | 6177 |
26 | Locked | 42 | 12459 | 6713 |
27 | Locked | 42 | 11758 | 6587 |
28 | Locked | 42 | 11185 | 6111 |
29 | Locked | 42 | 9924 | 5560 |
30 | Locked | 42 | 9932 | 6217 |
31 | Locked | 42 | 8364 | 5714 |
33 | 94 | 4K | 1840 | QAM 4096 | 1108 |
on 29-05-2024 19:01
0 | 49600000 | 46.8 | 5120 | QAM 64 | 1 |
1 | 43100000 | 46.3 | 5120 | QAM 64 | 2 |
2 | 36600000 | 46.5 | 5120 | QAM 64 | 3 |
3 | 30100000 | 46 | 5120 | QAM 64 | 4 |
4 | 23600000 | 45.8 | 5120 | QAM 64 | 5 |
3.1 Upstream channels
6 | 10.4 | 42.5 | 2K | QAM 256 |
6 | OFDMA | 208 | 74000000 | 1 | 0 |
on 30-05-2024 08:28
on 03-06-2024 10:14
Hi @Sebsebseb,
Thank you for your posts and welcome back to our community forums. We're here to help.
I'm sorry to hear you've been experiencing some connection issues recently. I've checked over things on our systems and I can't detect any faults currently that would explain these issues you've been facing. Are your service issues ongoing today, or have things improved since your posts?
on 03-06-2024 12:39
Hi Zach_R
The issue has been ongoing for months now (since last engineers visit) and is still affecting the service.
on 06-06-2024 14:16
Sorry to hear this, let me send you a DM and we can take a look.
Matt - Forum Team
New around here?
on 11-06-2024 15:30
Glad we've managed to get the ball rolling on this for you 🙂
Matt - Forum Team
New around here?
14-06-2024 18:56 - edited 14-06-2024 19:00
So we had engineer coming yesterday (thanks Matt). He checked all connection and signal, etc. Said nothing wrong and it must be a router. New router fitted, but after few hours connection was playing up again. Today, we are back in square one with internet connection dropping every 30 minutes or so.
New graph shows lost packages at the same rate as before replacement router
https://www.thinkbroadband.com/broadband/monitoring/quality/share/9ed7fec8f3f46fc6b71dba4dd8450bc42b83797d
