Cable for router
laney18
I need to reposition my router hub but the supplied cable is not long enough and need to move it 2m away. Does virgin media supply the cable or can I buy elsewhere 🤔
3 REPLIES 3
jpeg1
VM will supply a 3 metre cable free of charge, just wait for a staff person to pick this up.
Do not buy a 'compatible' cable on line or in a shop. They are not the same and could cause problems.
- jpeg1
My name is NOT Alessandro. That's just a tag Virginmedia sticks on some contributors. Please ignore it.
Sephiroth
It’s 100% OK to buy ready-made SHIELDED 75ohm coax cable terminated with BNC-connectors provided that you buy from a reputable source such as Amazon.  And you’ll get it faster.
Alex_RM
Hi laney18,
Thanks for posting and welcome to our community 😊
Let us know if you've been able to order a cable, if not we can pop you over a private message to do this.
Alex_Rm
