Lindsey5's avatar
Lindsey5
Broadband / tv issues
broadband and tv showing ‘fault’ when I ran a service status but unable to progress beyond this point to repair - possibly because the broadband isn’t functioning. Whatever the reason, when I click on ‘fix the problem’ I just have the buffering loop rolling for hours on end without progressing to the option to a) fix b) access an engineer. Not sure what to do next. This problem has been rolling on for nearly a week.
  • goslow's avatar
    goslow
    Try the automated service status number 0800 561 0061 to check for any faults in your area. If there is an area fault, VM does not send out technicians to individual customers until the area fault has cleared.
  • Ashleigh_C's avatar
    Ashleigh_C
    Hi there Lindsey5
    I am so sorry that you have faced this issue with your service and thank you again for posting. I can see there are a few issues with the connection on our side that would require an engineer to take a look. I'll be happy to get this booked for you via a private message.
