on 02-01-2024 20:11
Why am I paying £50 per month for this?
https://www.thinkbroadband.com/broadband/monitoring/quality/share/80173234d9ae65895b021bf97ec89c94d609b7e5-02-01-2024
The difficulties I'm having doing what I want to do online due to your service is beyond laughable. And I'm paying for it. Would Virgin Media think that witholding 15-20% of the bill to compensate for the service I'm getting is acceptable? I doubt it, but it's coming close.
So what's going on Virgin Media? How do I get you to fix the network I'm paying you a premium for?
on 02-01-2024 20:35
02-01-2024 22:28 - edited 02-01-2024 22:37
Lets see the rest of the data - can you do the below.
Also... what Hub model is it and what devices do you have plugged into the Hub on ethernet cables?
____________
In your browser’s URL box type in http://192.168.0.1 (or http://192.168.100.1 - if in modem mode) (DONT click these links) - and hit return. No need to log in - just click on the “Router Status” icon/text at bottom-middle (Hub3/4/5) or top/right (SH’s) - of the Login page.
Then… Navigate to these “data pages” and just copy/paste the normal “Formatted Text” (not images) 3 FULL sets of data onto here – 2 tables from the Downstream, 2 from the Upstream, & the Network Logs pages. Don't worry too much about the formatting it can be easily read & DON’T include personal data or MAC addresses - blank them out - if you copy/paste the data, the board software will do this for you (you may need to click the "submit" button again). If character limits are “exceeded” - just do two posts
on 03-01-2024 19:18
Hey, John, thanks for getting to me and sorry for the late reply. I've had a hectic 24 hours.
The device is the Hub 4 and the only devices running through ethernet are a DVR for the security cameras so I can remote access and my PC.
The tables are as follows:
Downstream:
25 | 331000000 | 4.199997 | 37.355988 | QAM256 | 25 |
1 | 139000000 | 2.200001 | 38.605377 | QAM256 | 1 |
2 | 147000000 | 2.500000 | 38.983261 | QAM256 | 2 |
3 | 155000000 | 2.500000 | 38.605377 | QAM256 | 3 |
4 | 163000000 | 2.000000 | 37.636276 | QAM256 | 4 |
5 | 171000000 | 2.099998 | 37.636276 | QAM256 | 5 |
6 | 179000000 | 2.599998 | 37.636276 | QAM256 | 6 |
7 | 187000000 | 2.799999 | 37.636276 | QAM256 | 7 |
8 | 195000000 | 2.500000 | 37.636276 | QAM256 | 8 |
9 | 203000000 | 2.299999 | 37.636276 | QAM256 | 9 |
10 | 211000000 | 2.500000 | 37.636276 | QAM256 | 10 |
11 | 219000000 | 2.700001 | 37.355988 | QAM256 | 11 |
12 | 227000000 | 2.700001 | 37.636276 | QAM256 | 12 |
13 | 235000000 | 2.299999 | 37.355988 | QAM256 | 13 |
14 | 243000000 | 2.299999 | 37.355988 | QAM256 | 14 |
15 | 251000000 | 2.700001 | 37.636276 | QAM256 | 15 |
16 | 259000000 | 3.400002 | 37.636276 | QAM256 | 16 |
17 | 267000000 | 3.700001 | 37.636276 | QAM256 | 17 |
18 | 275000000 | 3.299999 | 37.636276 | QAM256 | 18 |
19 | 283000000 | 2.799999 | 37.355988 | QAM256 | 19 |
20 | 291000000 | 2.900002 | 37.636276 | QAM256 | 20 |
21 | 299000000 | 3.900002 | 37.636276 | QAM256 | 21 |
22 | 307000000 | 4.599998 | 37.636276 | QAM256 | 22 |
23 | 315000000 | 4.400002 | 37.355988 | QAM256 | 23 |
24 | 323000000 | 4.500000 | 37.636276 | QAM256 | 24 |
26 | 339000000 | 4.500000 | 37.355988 | QAM256 | 26 |
27 | 347000000 | 5.199997 | 37.355988 | QAM256 | 27 |
28 | 355000000 | 5.400002 | 36.386890 | QAM256 | 28 |
29 | 363000000 | 5.000000 | 36.609653 | QAM256 | 29 |
30 | 371000000 | 3.900002 | 36.609653 | QAM256 | 30 |
31 | 379000000 | 3.799999 | 36.609653 | QAM256 | 31 |
25 | Locked | 37.355988 | 0 | 0 |
1 | Locked | 38.605377 | 0 | 0 |
2 | Locked | 38.983261 | 0 | 0 |
3 | Locked | 38.605377 | 0 | 0 |
4 | Locked | 37.636276 | 0 | 0 |
5 | Locked | 37.636276 | 0 | 0 |
6 | Locked | 37.636276 | 0 | 0 |
7 | Locked | 37.636276 | 0 | 0 |
8 | Locked | 37.636276 | 0 | 0 |
9 | Locked | 37.636276 | 0 | 0 |
10 | Locked | 37.636276 | 0 | 0 |
11 | Locked | 37.355988 | 0 | 0 |
12 | Locked | 37.636276 | 0 | 0 |
13 | Locked | 37.355988 | 0 | 0 |
14 | Locked | 37.355988 | 0 | 0 |
15 | Locked | 37.636276 | 0 | 0 |
16 | Locked | 37.636276 | 0 | 0 |
17 | Locked | 37.636276 | 0 | 0 |
18 | Locked | 37.636276 | 0 | 0 |
19 | Locked | 37.355988 | 0 | 0 |
20 | Locked | 37.636276 | 0 | 0 |
21 | Locked | 37.636276 | 0 | 0 |
22 | Locked | 37.636276 | 0 | 0 |
23 | Locked | 37.355988 | 0 | 0 |
24 | Locked | 37.636276 | 0 | 0 |
26 | Locked | 37.355988 | 0 | 0 |
27 | Locked | 37.355988 | 0 | 0 |
28 | Locked | 36.386890 | 0 | 0 |
29 | Locked | 36.609653 | 0 | 0 |
30 | Locked | 36.609653 | 0 | 0 |
31 | Locked | 36.609653 | 0 | 0 |
on 03-01-2024 19:18
Upstream:
1 | 43100000 | 46.020599 | 5120 KSym/sec | 64QAM | 2 |
2 | 23600000 | 45.520599 | 5120 KSym/sec | 64QAM | 5 |
3 | 30100000 | 45.520599 | 5120 KSym/sec | 64QAM | 4 |
4 | 36600000 | 46.020599 | 5120 KSym/sec | 64QAM | 3 |
5 | 49600000 | 46.020599 | 5120 KSym/sec | 64QAM | 1 |
1 | US_TYPE_ATDMA | 0 | 0 | 0 | 0 |
2 | US_TYPE_ATDMA | 0 | 0 | 0 | 0 |
3 | US_TYPE_ATDMA | 0 | 0 | 0 | 0 |
4 | US_TYPE_ATDMA | 0 | 0 | 0 | 0 |
5 | US_TYPE_ATDMA | 0 | 0 | 0 | 0 |
on 03-01-2024 19:25
Netlogs:
Wed Jan | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: ; New Profile: 12.;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1; |
Wed Jan | 3 | No Ranging Response received - T3 time-out;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1; |
Wed Jan | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: 12; New Profile: .;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1; |
Wed Jan | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: 11; New Profile: 12.;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1; |
Wed Jan | 5 | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1; |
Tue Jan | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: 11; New Profile: 12.;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1; |
Tue Jan | 5 | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1; |
Tue Jan | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: 12; New Profile: .;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1; |
Tue Jan | 3 | No Ranging Response received - T3 time-out;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1; |
Tue Jan | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: 12; New Profile: 11.;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1; |
Tue Jan | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: ; New Profile: 11.;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1; |
Tue Jan | 5 | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1; |
Thu Jan | 3 | No Ranging Response received - T3 time-out;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1; |
Tue Jan | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: ; New Profile: 12.;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1; |
Mon Jan | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: 11; New Profile: 12.;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1; |
Mon Jan | 5 | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1; |
Mon Jan | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: ; New Profile: 12.;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1; |
Mon Jan | 3 | No Ranging Response received - T3 time-out;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1; |
Mon Jan | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: 12; New Profile: .;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1; |
Mon Jan | 6 | US profile assignment change. US Chan ID: 6; Previous Profile: 12; New Profile: 11.;CM-MAC=;CMTS-MAC=;CM-QOS=1.1;CM-VER=3.1; |
on 05-01-2024 19:50
Good evening @LeeVM
Thanks for posting and welcome to the community. Very sorry for any broadband issues.
We've ran some checks here and there is a short-term connectivity issue ongoing. We've put your system on a 24 hour monitor and will check your connection over the next 24 hours. Once we’ve completed our checks, we’ll send you a text update to the mobile number on file.
If everything is back to normal we’ll let you know, but if we find there is still an issue we’ll arrange a service visit by one of our technicians to run additional checks.
If the time and date of the service visit isn’t convenient, you’ll be able to change it online at virginmedia.com/my-virgin-media
Best wishes
3 weeks ago
Hi @jJohn_GS
Would you care to elaborate on this reply for the wider audience. This seems to be a default scripted response with very little substance. I know this as I've had the same issues on a regular basis this year, various engineer visits and again today. The CS representative quote your response verbatim but refused to say what the issue is / was and why 24 hours. It always seems to rectify, consistently, in around 6-8 hours. You must know what the issue is to fix it and therefore you must be able to stop it from re-occurring. Or as I suspect, you're over subscribed and need to regularly balance your network rather than increasing capacity.
