on 25-01-2024 16:17
Requested another WiFi Pod on two separate occasions now. After chatting to someone on the webchat I was told the first order never went through for some reason, so a new order was raised and I was told the Pod would be delivered today 25th. I was told, I would receive an email from YODEL with a tracking number. You got it no message from Yodel and no Pod insight.
Any Virgin staff online can help me out please!
on 26-01-2024 16:13
Hi bobbymoore442,
We're sorry to hear you're had some issues with trying to order a new WiFi pod. This is something we can certainly check for you but in order to do that I will need to confirm some information with you to pass security.
I have sent you a direct message to allow us to do this with you in a private space. If you are using a PC/Laptop then you can just click on the little ✉ at the top right-hand side of the page to access your inbox. If you are on a mobile/tablet device then instead click on the little circle icon in the top right then select 'Messages'. 😊
