on 09-01-2024 22:05
Got a smart heating fan for my daughters bedroom.
Set it all up and went to connect it to my new super hub but it's only 2.4ghz connection and the hub is 5ghz.
Is there a way I can connect this device to a 2.4ghz frequency on my hub to get this to work.
on 09-01-2024 22:34
You should see 2.4 + 5ghz, if you open a Web browser and enter 192.168.0.1 and then your password to access your hub, then go to Advanced settings > Wireless signal and then tick the enable 2.4 GHz if it's not already ticked and then Apply changes.
on 09-01-2024 22:42
VM hubs transmit both 2.4Ghz and 5Ghz signals on a combined SSID. Some devices do not like this and refuse to work. If you do not have VM pods you can separate the bands into 2 SSIDs. Go into the settings on the hub and give the two SSIDs different names link xxx-2 and xxx-5. You can the connect the device to the xxx-2 SSID name. If you have VM pods is more lengthy, but come back if you need these instructions.
on 10-01-2024 09:55
Thank you i will have a go.
on 10-01-2024 11:27
Got both ticket in the settings but still not showing two options to connect with. The app for this is saying still it needs to connect to 2,4ghz.
on 10-01-2024 11:31
Its the Hub 4 i have if this helps.
on 10-01-2024 18:25
Hi valleyboy22,
If you have Virgin's wifi pods you need to have Channel Optimization enabled for them to work.
If you haven't got 5G and 2.4G bands then you need to split your Wi-Fi network, instructions on how to do that are in link below, when you have selected Advanced Settings you will also need to select Wireless, Wireless Signal and click on Disable Channel Optimization at the bottom then click on Apply Changes.
https://community.virginmedia.com/t5/Help/Splitting-your-home-WiFi-networks/m-p/4726309#M28
If you are using pods don't split your network.
on 17-03-2024 21:04
Hi, I would like those instructions please.
I have the pods so can't split my networks. But I have a smart TV which constantly disconnects and reconnects on the 5ghz network, so want to force it to connect to 2.4ghz only. Thanks.
on 18-03-2024 08:50
Time to retire the VM Pods & remove the VM Connect app, they are both blocking your way forward to a split SSID.
Invest in your own Wi-Fi Mesh / Access Points / Repeaters and you will have full control over the Wi-Fi network.
