4 weeks ago
Hi, I wonder if someone can help with this. I plugged in my pod this morning, and for some reason it now only shows 2g as an option when I look at my internet choices. Previously it showed both the 2g and 5g. However, when I click on 2g where you get information like download speed etc, it says 5ghz. Does that mean they are merged?
Thanking in advance
Answered! Go to Answer
4 weeks ago - last edited 4 weeks ago
Yes - when using the Pods you have to have "Smart wifi" enabled - this merges them into a single SSID.
Some like this arrangement for its convenience - I personally think its the work of Satan 😎
I prefer to have them separated (as I have) so I can choose which device connects on which band - when and where I choose.
4 weeks ago
The VM WiFi Pods only work with the Single SSID. The Intelligent WiFi will not work without this “out of the box” setup.
4 weeks ago
Have you either :
1) split the SSIDs on the VM Hub ?
2) turned off the 5GHz Wi-Fi band on the VM Hub ?
Either would result in a VM Pod only working on a single band.
4 weeks ago
Hi Thelyon5,
We're sorry to hear you're having issues with the Pod connecting.
There are a few requirements for the Pods to work with our Hubs. You can view these below:
As long as all of the above points are all met then the Pods will automatically connect to your Hub's WiFi and begin broadcasting. The wireless details from the Pods will be the same as the Hub's details, so no additional steps are required to connect up the devices in the home.
Once you've reverted your hub back to the above settings, if you continue to have issues, pop back and let us know so we can help further.
3 weeks ago
Thank you
3 weeks ago
Thank you. We're not sure what we prefer as it seems all our devices are in 5g, albeit it shows 2g. The five doesn't have the same reach as 2.
3 weeks ago
Thank you. No, we never touched anything. Both were showing before plugging in the pod. Definitely on shows 2g being available but when you look at the details on it says connected to 5g bandwidth.
3 weeks ago
Thank you. We never changed anything. I will think about doing a factory reset on the hub as I can't remember the password and I believe that's the only way to access it and check. However 100% sure SSIDs passwords are all the same .
3 weeks ago
How are you seeing the 2.4GHz and 5GHz signals .... I can only see that in a Wi-Fi Analyser app.
