philnumbers's avatar
philnumbers
11 months ago
2.4GHz WiFi grinds to a halt / unusable
Hello
I have an issue where my 2.4GHz WiFi connections grind to a halt and become unusable.
Ethernet and 5GHz are fine, speedy in fact and have no issues.
As far as I can tell the issue arises when our phones (iPhone 13 and 13 Pro) switch over to a 2.4 connection. Doesn't seem to happen to my Mac Book but maybe that is better at keeping the 5GHz connection?
I have a Hub 3 and have 2.4 & 5 both switched on with everything set to Auto / Enable Channel Optimization - I believe it has to be set like this for my plug in Virgin issued WiFi booster to work properly.
The greyed out channel on 2.4 shows Channel 6, I assume this is the channel it's using even though I can't manually change it. I have a Sonos system with various speakers, that is set to Channel 1.
Is poor 2.4 speed a known issue with Hub 3 and anything I can do to help fix it? I'm trying to get VM on the case but need to try again tomorrow on their chat so thought I'd ask here in the meantime. And I'm talking very slow, like a single simple page will take minutes to load, videos in YT / FB etc won't load.
Cheers
  • Steven_L's avatar
    Steven_L
    11 months ago
    Thanks for coming back to us philnumbers, have you been able to check for issues with the WiFi pod turned off as you mentioned earlier in the thread? We can then determine if the pod is causing the issues that you're experiencing.
    Kind Regards,
    Steven_L
