1Gig Hub5 Reducing buffer bloat
smithy01793
Howdy all hope everyone is well
So as the Subject says i am getting a lot of buffer bloat on mt hub5
Firstly Info for you- Using the 2.5 gig port (Hub5) to my10gig network port on my pc,
Have performed standard checks and tests however i can not seem to reduce the buffer bloat at the Hubs end,
Even gone as far as have only 1 device on there my wired pc and doing multipole Downloads - uploads in this config, Burst Dl,s and ul.s  and single bigger files in both directs and a mix of files big small in both directions as well.
Latency Performance - Idel Average 20-53ms . Download Average 197-244ms. Upload 23-29ms
Every time getting a Result of  F ,Context on this result is monitoring the results A to F,
A-best possible F-Worst Possible.
Running latest firmware that i am aware of at this time for the Hub5.7.6.15-2306.5
3 REPLIES 3
Depending on who says what and how you may not like the answer
So can you do something about buffer bloat the answer is yes but also no
VM has limited bandwidth to which you may not always hit your upto speed which the problem amplified by your fast upto.
Can you do anything about bufferbloat IF bandwidth is available on the network YES simple buy a QoS/BWM router and rate limit for 1Gb port 900Mb download and 99Mb upload or on 2.5Gb port 1100Mb down and 99Mb up. For the download QoS/BWM to work it necessary to limit under your max speed for the QoS/BWM to work.
But what happens IF bandwidth is not available on the network to give you your full speed? This can depending on the area QoS/BWM used that your own QoS/BWM will not see in order for it to control the limit and so you buffer bloat never hitting your upto speed.
Sephiroth
Even I understood Legacy's reply this time.  He has made two very good points.  If I were you, I would focus on his 'NO' point first.  In other words, is the VM circuit delivering your full bandwidth, particularly at peak times?
ns006m
If you have a 2.5gig connection then the rj45 cable and pc network card must also be 2.5gig.
Your pc is looking for a 10gig connection and not getting it.
