Use extection cable to move phone
Hosay299
Superfast
Hi are we able to use the phone on extention lead on the new hub connection??
1 ACCEPTED SOLUTION
Accepted Solutions
You are very welcome, I am sure you will get this set up suited to you, I understand a Landline isn't for everyone either is a Mobile, if you do need any further support, please do not hesitate to reach back out.
Paul.
14 REPLIES 14
Certainly, not a problem.
Hi thanks canu get a cable that would just plug from the router to the back of phone instead off the white filter thing ??
Hi @Hosay299,
Thank you for your post. I am sorry no, as inside is a convertor that does require something sizable to contain the components to make the switch possible. You can buy a VOIP phone for this if you wish.
Zoie
"Hi thanks canu get a cable that would just plug from the router to the back of phone instead off the white filter thing ??" You probably can, but it might be a hit and miss as all cable are not wired the same.
Hi ok but why is vm staff saying no??
I have seen a cable that can plug into back of phone to router.
When on computer later on I will share more information
Kain_W
Hi Hosay299,
Sorry just to clarify, havd you recently switched over?
Are you looking to keep your landline within the same room it's already in?
Let us know,
Kain
"Hi ok but why is vm staff saying no??" Simply that they will not guarantee anything other than their ‘dongle’ working.
Hi Kain, We where on the phone when we joined u just would like to know if the phone will work with a extion cable on it to move the phone to another part of the room
and if we can use a cable like this  Here and more like this
What i want to know can i use this from the vm router to the back of the phone  here
With out having the wite convtor thing
