KeithieW's avatar
KeithieW
Problem with land line not ringing.
For a week or so my landline phone is not ringing when receiving calls. Now a relative has told me that they’re getting no answer when calling me and the answerphone isn’t kicking in. I’ve checked it by phoning it myself using mobile and my landline phone is not ringing when call. I can make calls out.
If I watch the screen of my landline phone when I’m calling it, it displays that a call is coming in, however, it doesn’t cut in the answerphone so the call doesn’t get picked up and sounds to the caller as though it’s just ringing and ringing but there is no sound at all being made in my phone.
If I pick up and answer while ringing it myself the call connects.
I have checked the volume of ringtone on handset and base is set to maximum and I have used the find phone function to check the sounds work. I have contacted the phone manufacturers and told them the problem I am having and they say it is not an issue with my handsets.
I need to have a working landline phone because I am having treatment for a medical condition and get calls from my medical team fairly regularly.
Please help.
Keith Waye
  • Alex_RM's avatar
    Alex_RM
    Hi Keith,
    Thanks for posting and sorry to hear you're having some issues with the line.
    Just to rule it out, can you confirm if you've been able to test a different handset?
    Alex_Rm
      • Alex_RM's avatar
        Alex_RM
        Thanks for confirming  😊
        So I can get a few more details from you. I've popped you over a private message.
        Alex_Rm
  • Hello, we are experiencing exactly the same issue. We can hear a tone when picking up the handset but incoming calls are not ringing.
    • Sabrina_B's avatar
      Sabrina_B
      Hi blanaspre 👋.
      Thanks for reaching out to us and welcome to the Community Forums. Apologies you are having these issues with your home phone, so that we can look into this further with you, we would need to bring you in for a private message.
      Please look out for the envelope on the top right of your web browser or if you are using a mobile device, it will be located under your profile icon.
      Thanks.
      Sabrina
