20-03-2024 15:00 - edited 20-03-2024 15:02
My copper telephone cable runs in my front garden but my broadband & tv is connected onto next doors cabling, via a couple of splitters, which runs in their garden.
So now if they dig up their cables not only do I loose my broadband and TV but also my phone as well
Could it all be connected onto my cables rather that next doors like it always used to be
20-03-2024 15:12 - edited 20-03-2024 15:15
The reason you likely have a shared connection is there is a problem with the underground duct servicing your property. Rather than doing a major construction exercise in the pavement outside they have split the neighbours connection, something that happens quite often.
I can see you having an uphill battle to get anything done if the current arrangement is not causing service issues, especially as all current connections are being replaced with full fibre in the not too distant future. One of the reasons your phone service has moved to the hub is to bring in full fibre operation.
on 20-03-2024 15:14
Hi edam,
Thank you for reaching out to us in our community and welcome back, sorry to hear your cable is attached to your neighbours which causes you concern, in most cases the copper phone cable is no longer used and ours is connected with the Internet and TV, if you have a separate phone cable this is likely to be from another provider, you advised the cables used to be fed differently, when was this changed?
Paul.
on 21-03-2024 14:23
it was done a few years back when I had problems with my TV and rather than replacing the cable they connected me onto next doors cable using a 4 way splitter. My virgin phone was still connected to the old siameese cable ..
on 21-03-2024 14:31
Hi @edam
Thanks for coming back to the thread. Nodrogd has advised perfectly here, sometimes we do these things if there's an issue with the ducting etc but it shouldn't cause any issues :).
Are they planning on digging up cabling? Best wishes.
