Polster's avatar
Polster
Low PS5 download speed via ethernet cable
I recently replaced my PS4 with a PS5 and thought the new console would work well with my Hub 5. Unfortunately I am still suffering from slow download speeds, at best approx. 85MB.
I am connected via a CAT 7 Ethernet cable to a Virgin Pod. I have tested the cable and pod with a laptop and am able to get over 400MB download speeds.
I am only able to get about 80MB if I try WiFi.
Upload speeds are reasonable at 90-100MB.
Any idea why both the PS4 and PS5 cannot reach far better download speeds?
  • I recently replaced my PS4 with a PS5 and thought the new console would work well with my Hub 5. Unfortunately I am still suffering from slow download speeds, at best approx. 85MB.
    • Ashleigh_C's avatar
      Ashleigh_C
      Hi there Polster
      I am so sorry to hear that you are facing issues with your console! Can I just confirm, have you connected the console via Ethernet to the Pod?
      • Polster's avatar
        Polster
        Yes, the console is connected by Cat 7 Ethernet cable to the Pod.
    Just check the PS5 is negotiating a Gigabit connection with the Pod, and not a 100Mb one.
