martin10991's avatar
martin10991
8 months ago
Connection Issues - Dropped packets and variable latency
Over the last few months, I've been experiencing dropouts and latency issues on my Virgin home broadband, which impacts wired and wireless connections. This particularly affects WiFi calls, Video calls, and streaming. We recently switched over to Virgin from Vodafone and are using it in MODEM mode.
The problem was particularly bad when work was being done on our local network (fitting fibre). I've had multiple technician visits who have checked all the connections, (replacing some due to observed poor terminations), fitted a new Hub 5 and run numerous tests on power to the house and router, which they report as within normal limits, noting that we are several hundred meters from the street cabinet.  For a few weeks after the last visit, things were markedly better, but then it deteriorated again, and we now get daily problems.
One difficulty is that the problem is intermittent, so whilst all may be good for a few days, we then have days of problems.  I'd really appreciate any help at all getting to the root cause of this, as I find it very difficult getting hold of anyone via Virgin Customer Services to do more than book a repeat appointment, eventually resulting in a technician visiting to repeat the same things!
Based on advice in other posts that I've read, I'm attaching here the log details, which I'd be really grateful if someone could kindly review and provide feedback on what I should do!
MANY thanks in advance...
Example graphs from BQM follow on variety of days:
Cable Modem Status
Item
StatusType
Cable Modem StatusOnlineDOCSIS 3.0
Primary downstream channelLockedSC-QAM
Channel OverviewDownstreamUpstream
DOCSIS 3.0 channels315
DOCSIS 3.1 channels11
Data follows...
  • legacy1's avatar
    Hard to tell what router mode is doing might be ARP loss to the gateway or just intermittent noise on Docsis
  • Network Logs:
    Time      Priority Description
    09-05-2025 12:38:00     notice    GUI Login Status - Login Success from LAN interface
    09-05-2025 12:09:14     notice    GUI Login Status - Login Success from LAN interface
    09-05-2025 11:43:25     notice    GUI Login Status - Login Success from LAN interface
    03-05-2025 09:15:21     error      DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=XX:XX:XX:XX:XX:XX;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.1;
    30-04-2025 07:25:44     notice    REGISTRATION COMPLETE - Waiting for Operational status
    30-04-2025 07:25:39     warning                RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=XX:XX:XX:XX:XX:XX;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.1;
    30-04-2025 07:25:38     warning                Dynamic Range Window violation
    30-04-2025 07:25:38     warning                RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW;CM-MAC=XX:XX:XX:XX:XX:XX;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.1;
    30-04-2025 07:25:31     notice    DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=XX:XX:XX:XX:XX:XX;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.1;
    30-04-2025 07:25:30     notice    TLV-11 - unrecognized OID;CM-MAC=XX:XX:XX:XX:XX:XX;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.1;
    30-04-2025 07:25:23     warning                DHCP WARNING - Non-critical field invalid in response ;CM-MAC=XX:XX:XX:XX:XX:XX;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.1;
    30-04-2025 07:25:21     notice    Honoring MDD; IP provisioning mode = IPv4
    30-04-2025 07:25:12     critical   No Ranging Response received - T3 time-out;CM-MAC=XX:XX:XX:XX:XX:XX;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.1;
    30-04-2025 07:25:06     critical   SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=XX:XX:XX:XX:XX:XX;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.1;
    30-04-2025 07:25:04     critical   Cable Modem Reboot because of - HW or Power-On Reset
    04-04-2025 13:12:50     critical   No Ranging Response received - T3 time-out;CM-MAC=XX:XX:XX:XX:XX:XX;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.1;
    04-04-2025 13:12:43     critical   SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=XX:XX:XX:XX:XX:XX;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.1;
    04-04-2025 13:12:41     critical   Cable Modem Reboot because of - Reboot UI
    04-04-2025 10:48:14     critical   Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=XX:XX:XX:XX:XX:XX;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.1;
    04-04-2025 10:48:14     critical   16 consecutive T3 timeouts while trying to range on upstream channel 8;CM-MAC=XX:XX:XX:XX:XX:XX;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.1;
    04-04-2025 10:47:06     critical   Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=XX:XX:XX:XX:XX:XX;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.1;
    01-04-2025 10:52:31     critical   SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=XX:XX:XX:XX:XX:XX;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.1;
    01-04-2025 10:52:26     critical   Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=XX:XX:XX:XX:XX:XX;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.1;
    01-04-2025 10:52:21     critical   SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=XX:XX:XX:XX:XX:XX;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.1;
    01-04-2025 10:52:20     critical   Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=XX:XX:XX:XX:XX:XX;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.1;
    01-04-2025 10:52:00     critical   Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=XX:XX:XX:XX:XX:XX;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.1;
    01-04-2025 10:52:00     critical   SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=XX:XX:XX:XX:XX:XX;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.1;
    01-04-2025 10:51:59     critical   SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=XX:XX:XX:XX:XX:XX;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.1;
    01-04-2025 10:51:59     critical   Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=XX:XX:XX:XX:XX:XX;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.1;
    01-04-2025 10:51:58     critical   Received Response to Broadcast Maintenance Request, But no Unicast Maintenance opportunities received - T4 time out;CM-MAC=XX:XX:XX:XX:XX:XX;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.1;
    01-04-2025 10:49:26     critical   SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=XX:XX:XX:XX:XX:XX;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.1;
    01-04-2025 10:42:09     critical   SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=XX:XX:XX:XX:XX:XX;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.1;
    01-04-2025 10:42:07     critical   SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=XX:XX:XX:XX:XX:XX;CMTS-MAC=XX:XX:XX:XX:XX:XX;CM-QOS=1.1;CM-VER=3.1;
  • Network Log:
  • legacy1's avatar
    Yes intermittent are hard cases as your in modem mode BQM would be to your router/device so cable could be a  problem or your router/device.
    it be best to get a new cable and hook a PC to the hub in modem mode you can get another NIC PCI-e/USB to do internet connection sharing with your router as you test BQM to your PC. Or put hub in router mode but then this might show fine but the LAN ports are bad on the hub
    • martin10991's avatar
      martin10991
      thanks, sorry: I mis-read the hub's pages: I'm using it in Router Mode.   All the stats/tests were with the unit set up like that.
      (we were previously using Virgin in Modem mode with a separate Router; replacing that setup with the new Hub in Router mode seemed to improve overall latency, but I'm still left with the variability and drop outs shown in the BQM pictures)
      • Robert_P's avatar
        Robert_P
        Hello martin10991
        Sorry to hear of the intermittent connection issues impacting both your wired and wireless connections, we appreciate you raising it with us via the forums and welcome to the community.
        We're eager to take a closer look at this for you and I will send you a Private Message, please keep an eye out in the top right when signed into the forums for the envelope. This is where you will be able to find my Private Message and be able to respond.
  • Live BWM Link: https://www.thinkbroadband.com/broadband/monitoring/quality/share/d74903c23ad7b08997819a83b42346cb99687fca
      martin10991
  • 3.0 Upstream channels
    Channel
    Frequency (Hz)
    Power (dBmV)
    Symbol Rate (ksps)
    Modulation
    Channel ID
    0
    49600000
    48
    5120
    QAM 64
    1
    1
    43100000
    47.8
    5120
    QAM 64
    2
    2
    36600000
    47.5
    5120
    QAM 64
    3
    3
    30100000
    47
    5120
    QAM 64
    4
    4
    23600000
    46.8
    5120
    QAM 64
    5
    Channel
    Channel Type
    T1 Timeouts
    T2 Timeouts
    T3 Timeouts
    T4 Timeouts
    0
    ATDMA
    0
    0
    0
    0
    1
    ATDMA
    0
    0
    0
    0
    2
    ATDMA
    0
    0
    0
    0
    3
    ATDMA
    0
    0
    0
    0
    4
    ATDMA
    0
    0
    2
    0
    3.1 Upstream channels
    Channel
    Channel Width (MHz)
    Power (dBmV)
    FFT Type
    Modulation
    6
    10.4
    43.5
    2K
    QAM 256
    Channel
    Channel Type
    Number of Active Subcarriers
    First Active Subcarrier (Hz)
    T3 Timeouts
    T4 Timeouts
    6
    OFDMA
    208
    74000000
    0
    0
    General Configuration
    Network access
    Allowed
    Maximum Number of CPEs
    1
    Baseline Privacy
    Enabled
    DOCSIS Mode
    3.1
    Config file
    cmreg-vmdg660-bbt060-b.cm
    SFID
    86136
    Max Traffic Rate
    287500061 bps
    Max Traffic Burst
    42600bytes
    Min Traffic Rate
    0 bps
    Primary Upstream Service Flow
    SFID
    86135
    Max Traffic Rate
    27500061 bps
    Max Traffic Burst
    42600bytes
    Min Traffic Rate
    0 bps
    Max Concatenated Burst
    42600bytes
    Scheduling Type
    Best Effort
  • 3.0 Downstream channels
    Channel
    Frequency (Hz)
    Power (dBmV)
    SNR (dB)
    Modulation
    Channel ID
    1
    306000000
    0.5
    41
    QAM 256
    22
    2
    138000000
    1.3
    39
    QAM 256
    1
    3
    146000000
    1.1
    39
    QAM 256
    2
    4
    154000000
    1.2
    39
    QAM 256
    3
    5
    162000000
    1.2
    39
    QAM 256
    4
    6
    170000000
    0.9
    39
    QAM 256
    5
    7
    178000000
    0.9
    40
    QAM 256
    6
    8
    186000000
    0.8
    40
    QAM 256
    7
    9
    194000000
    0.9
    40
    QAM 256
    8
    10
    202000000
    0.7
    40
    QAM 256
    9
    11
    210000000
    0.7
    40
    QAM 256
    10
    12
    218000000
    0.7
    40
    QAM 256
    11
    13
    226000000
    0.7
    40
    QAM 256
    12
    14
    234000000
    0.8
    40
    QAM 256
    13
    15
    242000000
    0.7
    40
    QAM 256
    14
    16
    250000000
    0.4
    40
    QAM 256
    15
    17
    258000000
    0.4
    41
    QAM 256
    16
    18
    266000000
    0.4
    40
    QAM 256
    17
    19
    274000000
    0.3
    41
    QAM 256
    18
    20
    282000000
    0.6
    41
    QAM 256
    19
    21
    290000000
    0.6
    41
    QAM 256
    20
    22
    298000000
    0.6
    41
    QAM 256
    21
    23
    314000000
    0.3
    40
    QAM 256
    23
    24
    322000000
    0.1
    40
    QAM 256
    24
    25
    330000000
    0.3
    40
    QAM 256
    25
    26
    338000000
    0.3
    41
    QAM 256
    26
    27
    346000000
    0.3
    41
    QAM 256
    27
    28
    354000000
    0.4
    41
    QAM 256
    28
    29
    362000000
    0.3
    41
    QAM 256
    29
    30
    370000000
    0.5
    41
    QAM 256
    30
    31
    378000000
    0.7
    41
    QAM 256
    31
    Channel
    Locked Status
    RxMER (dB)
    Pre RS Errors
    Post RS Errors
    1
    Locked
    41
    208
    0
    2
    Locked
    39
    450
    0
    3
    Locked
    39
    432
    0
    4
    Locked
    39
    386
    0
    5
    Locked
    39
    346
    0
    6
    Locked
    39
    323
    0
    7
    Locked
    40
    299
    0
    8
    Locked
    40
    314
    0
    9
    Locked
    40
    263
    0
    10
    Locked
    40
    296
    0
    11
    Locked
    40
    287
    0
    12
    Locked
    40
    248
    0
    13
    Locked
    40
    245
    0
    14
    Locked
    40
    233
    0
    15
    Locked
    40
    188
    0
    16
    Locked
    40
    204
    0
    17
    Locked
    41
    224
    0
    18
    Locked
    40
    209
    0
    19
    Locked
    41
    215
    0
    20
    Locked
    41
    196
    0
    21
    Locked
    41
    181
    0
    22
    Locked
    41
    209
    0
    23
    Locked
    40
    259
    0
    24
    Locked
    40
    264
    0
    25
    Locked
    40
    232
    0
    26
    Locked
    41
    254
    0
    27
    Locked
    41
    197
    0
    28
    Locked
    41
    190
    0
    29
    Locked
    41
    205
    0
    30
    Locked
    41
    201
    0
    31
    Locked
    41
    248
    0
    3.1 Downstream channels
    Channel
    Channel Width (MHz)
    FFT Type
    Modulation (Active Profile)
    33
    92
    4K
    1800
    QAM 4096
    1128
    Channel ID
    Locked Status
    RxMER Data (dB)
    PLC Power (dBmV)
    Corrected errors (Active Profile)
    Uncorrectable errors (Active Profile)
    33
    Locked
    41
    -2.9
    617758368
    78
