tulobko1's avatar
tulobko1
Just joined
Flash VM Hub 3 with PFsense
I was thinking of it would be possible to flash the VM hub 3 with pfsense the router does not have usb so I guess there would be some way through ssh?
  • Tudor's avatar
    There is no way whatsoever to get into the firmware of the VM hubs. Just use modem mode with your own router and then you can do what you like.
  • legacy1's avatar
    Be thankful there IS modem mode as you never know may be gone with the move to fibre if VM gets there way
