waynepusb's avatar
waynepusb
Just joined
5 months ago
Wifi signal
Hi, I had virgin broadband fitted on Monday and it has been working fine but this morning their is no WiFi signal, is virgin down?
  • goslow's avatar
    goslow
    Do you mean you have lost your wi-fi connection (from the VM hub to your device) or do you mean you have lost your broadband connection (to your VM hub)?
    If it is the latter, try the automated service status number 0800 561 0061 to check for any faults in your area.
    • John_GS's avatar
      John_GS
      Hi waynepusb
      Thanks for posting and welcome to the community. Sorry to hear of the broadband issues.
      I'll send you a PM as from our checks, you'll need an engineer visit.
      Best wishes.
