Di-Baggo's avatar
Di-Baggo
WiFi Pods help
Hi there - can anyone help ?
I had one pod with limited WiFi in other rooms . I got another and all connected no problem but now both are worse than it was without any ‘ ! ?
  • Tudor's avatar
    Are he pods halfway between he VM hub and the location of the target machine/mobile? They must not be in the same location as the target.
    • Di-Baggo's avatar
      Di-Baggo
      Cheers - they in different locations
      I had one in hallway on ground floor where the connection was always great. I then had another to improve signal on first floor on bedroom. The connection on both is now poor and keeps dropping out. Have tried resetting ?
      • Tom_W1's avatar
        Tom_W1
        Hi Di-Baggo thanks for your post here although we're sorry to hear of your concerns raised here.
        As Client62 has advised, are you sure your devices are in fact connected to the WiFi Pods themselves, and not the main Hub network as they do have the same names?
        We'd advise using the Connect App for further help as you should be able to identify this there.
        Many thanks
    Are you sure your devices are connecting via the VM Pods ?
