Renwick's avatar
Renwick
Wifi pod troubles - devices randomly disconnect
Hi, I’ve seen a few similar posts from a while ago where the best answer always seems to be ‘put the hub in modem mode and buy a £400 mesh system’ - but I’m hoping someone might have found a solution recently.
I have the Hub 3 and two pods to cover a three-storey house. When things work, we have excellent connection and speed throughout the house. However, various devices (apple and Samsung phones, laptops) lose connection to the pods frequently. When this happens, they then refuse to reconnect - you have to turn the device wifi off and on about ten times or restart it, sometimes it says the password is incorrect/ sometimes it just says connection failed, until magically it reconnects and everything is fine.
Then you go downstairs and it drops off and you’re back in the same loop.
I can’t turn the intelligent wifi off because then the pods disconnect entirely. I’ve tried reserving IPs for the mobile devices without noticeable improvement. We’ve had an engineer round who found nothing wrong. Any ideas?
