garethleetaylor's avatar
garethleetaylor
Dialled in
WIFI POD HOT & BLACKENED WALL
Hey. This seems to be a common problem with these pods. I’ve had two of my three now overheat and damage my sockets/walls with black smoke? I’ve switched them all off for now for safety but this is impacting my internet coverage in my home. How do I get replacements and is there an alternative available?
  • Hello garethleetaylor
    Very sorry to see the issues caused by your Pod's and the concern this has caused, we appreciate you taking the time to raise this via the forums.
    I will send you a Private Message, please keep an eye out in the top right when signed into the forums for the envelope. This is where you will be able to find my Private Message and be able to respond.
  • jbrennand's avatar
    If this has happened on more than one Pod I would suggest you get a qualified electrician to look into any  socket where that has occurred . The old boosters are known to be prone to this... but AFAIK the Pods aren't.  At least I have never seen multiple pods causing this issue
    Please update this thread with the outcome so we can note the solution.  Thanks
    BTW - yes there are many options for improving the wifi connection that dont involve Pods - you can source your own...
    ... you would need to get either a… (1) Mesh System, (2) Wireless router, (3) Wireless access point(s), (4) a pair of good quality Wifi Powerline Adaptors, or a combination of (2&3). £40-100 - should sort it for most customers with an average property and usage.
    Spend more for additional advanced“features” - if required.
    • garethleetaylor's avatar
      garethleetaylor
      Dialled in
      It’s a new build house, only been here 10 years and lived in it from new. Never had a problem with the electrics or any other devices. It’s unlikely to be an electrical fault and is much more likely to be the pods themselves. They get to a ridiculous temperature.
      garethleetaylor
      Dialled in
      Still no solution thus far. I was messaged by a Virgin Media Rep, who at the time was very helpful and apologetic however, despite being told that a complaint has been raised and I would be contacted by Virgin Media for an Engineer to attend my home and inspect the issue and replace the pods, there has been no contact over a number of (working) days. I find this quite alarming given the potential risks posed by the pods but in the meantime continue to suffer poor internet coverage across my home whilst I await a solution/resolution.
  • asim18's avatar
    asim18
    Rising star
    If I was the CEO of VM I'd be posting that dodgy pod to Big Clive along with a blank cheque to find out exactly what went wrong.
    Has VM ever actually investigated these items? or do they just end up in an executive's bin?
    Wait, does VM even have a mechanism in place for such important information to reach someone who has the executive power to launch an investigation?
  • jb66's avatar
    jb66
    Is it near a radiator or is your house abnormally warm, the fact it's happened to more than one suggests it's an environmental factor
      garethleetaylor
      Dialled in
      Not sure why you would assume that. One is upstairs, on a landing area with lots of airflow and nowhere near a radiator and the other is near the front door, again with lots of airflow and nowhere near a heat source. My home never goes above 19.5 degrees.
  • Update - Despite Robert from the Forum Team being very helpful, I’ve had no direct call back from Virgin regarding this issue even though this has been promised on two separate occasions. I have pushed this myself and as a result, an Engineer visited yesterday and removed the three pods and photographed the damaged. According to him, this is not the first time he has seen this issue and he himself had a pod that literally exploded when it was plugged in, which he also reported to Virgin and had replaced. Unfortunately, he isn’t allowed to replace the pods with alternatives or even order them on my behalf, so I continue to chase and am no left without coverage across most of my home in the interim period.
  • Update 2 - Honestly, the service that Virgin Media provide is shocking. Despite having a call from a member of the Executive Team on Tuesday, reassuring me that they were now handling my complaint and leading on the issue, I am still no further forward. With all of the previous pods being taken by the Engineer, only one of the pods has so far been replaced. The Executive Team member stated that once activated (Tuesday) it would trigger an alert his end, for them to then send the second pod and then the same process for the third pod. Four days on, no further update or contact from Virgin Media and no way of getting in touch with the person directly handling my complaint. Really, really poor service despite the promises made!
  • Hi I can’t believe yours happened 11 months ago. Did Virgin ever give you a proper solution or explanation for what caused it? It’s really worrying that this has happened before and clearly hasn’t been addressed.
    In our case, the soot is literally all over the house and the engineer tonight could see the extent of it straight away. Walls, pictures, carpets, plastics, even a film across most of the windows. My daughter’s room was only decorated a few weeks ago and her carpet is already ruined. I’ve told Virgin there’s absolutely no way I will have the pods again after this, it’s caused far too much damage and I don’t trust them.
    If you don’t mind sharing, what did they end up doing for you back then? It would really help to know.
    kerry
    • jpeg1's avatar
      jpeg1
      The only way to get this resolved is to take it to Trading Standards, as was suggested 11 months ago. It's their job to investigate faulty goods like this.
      • KerryJ1975's avatar
        KerryJ1975
        Already done that thanks and only way in my book to get this resolved is VM to get my house back to some kind of normal not having everything covered in soot 👍
    • Robert_P's avatar
      Robert_P
      Hello KerryJ1975
      We're very sorry to hear of the Pod issues and damage caused to your property, this clearly isn't the standard we expect from any of the equipment we offer. We appreciate you raising this via the forums and welcome to the community.
      We're eager to look into this and assist as much as possible, I will send you a Private Message, please keep an eye out in the top right when signed into the forums for the envelope. This is where you will be able to find my Private Message and be able to respond.
        KerryJ1975
        Hi no message has come through but I’m already in touch with the Executive complaints team.
        thank you
  • This has happened to me and trading standards are collecting my pods tomorrow.
    this is a major safety issue these have damaged my proposal it’s full of soot report this the the Executive Team this should not happen!!
     The worst one is only 3 weeks old as was a replacement.  3 rooms need repainting and a carpet and a full deep clean.
      Take care with that idea, they are not your pods they are the property of Virgin Media who may proceed to charge your account a goodly amount for failing to return them.
      • HughJarsse's avatar
        HughJarsse
        Knows their stuff
        I think if the Trading Standards have taken them, then VM are not going to get much joy trying to 'charge the account holder for failing to return them' if  TS decide to make a big issue of it, that's for sure.
        More likely TS could charge VM for providing 'faulty goods' which 'could' possibly endanger lives.
