emc01's avatar
emc01
Wifi pod has disconnected and won't reconnect
Hello,
I've had the white wifi pod for 2 months now and it's been working great, up until a few days ago. The light is now constantly flashing white. I've tried resetting the hub 3 , both on the connect app and by pushing the reset button on back of hub. Have turned hub off at the wall and also tried the wifi pod in 2 other sockets, but still getting the white light.
I removed the wifi pod from the connect app thinking I could just reinstall it... but the app just says "that's it, your wifi pod should be up and running now" when I try
Not sure if this is normal or worth mentioning - but around the time the pod stopped working, I noticed a high pitched frequency noise coming from the fibre box thats inside the house, on the wall.
Any ideas? 😀 thank you
    Have you tried following the online pod trouble shooting guide?
    https://www.virginmedia.com/help/check/status/guide/pod-troubleshooting/start
  • jpeg1's avatar
    jpeg1
    Check if the pod is getting hot. Those white pods have been known to fail and burn.
    ** My name is NOT Alessandro **
    • emc01's avatar
      emc01
      It was getting quite hot yes, thanks. Got sorted on live chat. Replacement being sent out 🙌🏻
      • Matthew_ML's avatar
        Matthew_ML
        Glad to hear this was replaced emc01, let us know if you need anything else.
