jon30red's avatar
jon30red
Wifi pod fan noise
I've just received a replacement wifi pod as the previous was faulty.
However, the replacement is extremely noisy and the fan is constantly going into overdrive.
Any suggestions would be greatly appreciated, thanks.
  • Hey jon30red, thank you for reaching out and I am so sorry to hear about your pod.
    Please can you try this step and let us know if it fixes it or not;
    Unplug any Ethernet cables attached to the router and wait at least 30 seconds, then plug them back in. Plug the router's power cable back into the outlet. Plug the modem back in and wait until the modem has finished powering on. Wait at least 2 minutes for your Pods' LEDs to stop blinking.
    • jon30red's avatar
      jon30red
      Hi Matt, thanks for your response.
      I've followed your instructions and I still have the same issue unfortunately.
      Thanks, Jon
      • Alex_RM's avatar
        Alex_RM
        Thanks Jon,
        So I can take a closer look I've popped you over a private message.
        Alex_Rm
