mattl4's avatar
mattl4
Just joined
Wifi not reaching our office- alternative options to extend beyond Wifi Pods
Hi everyone, looking for some advice.
We currently have a Volt M250 package with Virgin. The signal generally has been good within the home, the issue is that our Wifi does not extend to our office. We live in a middle terrace & we have an outbuilding at the back of the property which functions as an office. Since moving in, we've been unable to get Wifi there. our telephone connection (& therefore Wifi hub) is at the front of the property.
I've contacted Virgin who have provided two Wifi Pods which we have placed as far back in the property as we can in the hopes that it would extend the Wifi to the office, with no success. I think the issue comes that the pods have to essentially extend the network through two brick walls? The reason I say this is that the distance between the Wifi pods/extenders & the office is no more than 10-15feet.
Anyway, my question now is what are our options? I'm left wondering if there is a stronger extender that may be able to fix the issue, or if I will need to bite the bullet & look into fitting ethernet cables to extend more effectively.
  • Tudor's avatar
    Another option if you have deep pockets is a 60Ghz point to point link.
  • Sephiroth's avatar
    Sephiroth
    There s another solution:  Powerline Adapters (e.g. Devolo) which will carry the Internet over the mains.  Provided that your office is n the same distribution board as your ring main, that will work.  I've used this method to carry Internet to my scattered TV360 boxes & TVs.  If your mains isn't too dirty, you can expect 100 meg at the furthest end.
  • jpeg1's avatar
    jpeg1
    The only guaranteed solution - and the cheapest - is an ethernet cable.
  • Roger_Gooner's avatar
    Roger_Gooner
    The best option by far is to run an exterior rated Ethernet cable into the outbuilding.
