CvC's avatar
CvC
Just joined
11 months ago
WiFi keeps dropping out or so poor it’s causing calls to pixelate/sound to go
We’ve just switched to Virgin and the internet connection has been completely awful. We both WFH and have regularly had to use our mobile data to have enough connection to run a Teams call without it dropping out. The broadband test says connection is fine, we’ve checked all the plugs are in, makes no difference. How can I get help with this? Or is just better to cancel and go with another provider?
  • Hey CvC, thank you for reaching out and a very warm welcome to the community, we are sorry to hear you are having some connection issues.
    We've taken a look and your connection looks great, how has it been over the last few days?
    Post the network log and power level stats from the Hub.  Run the FULL test on this site using a direct wired connection and post the results.   http://www.samknows.com/realspeed
    Note there is no SLA’s on a residential contract. If WFH is important then a backup solution would be advisable, e.g. a SIM based router.
