rukhsanabd7's avatar
rukhsanabd7
Just joined
15 days ago
Wi-Fi hopeless!!
Hi so our household has been with virgin for a long time, we had an older hub which was great.  Anyway, my housemate moved out and so I got a new virgin contract, and the speed is excellent wired!  However, Wi-Fi is a big disappointment.  My friend came around and changed channels and changed some settings but still it's awful! I have Wi-Fi 6 devices here at home, yet virgin have given me a hub 3!  I was really expecting something great for Wi-Fi and went with virgin as I heard their new hub does Wi-Fi 6? Is there any way I can simply get a new hub - the Wi-Fi 6 hub?  Otherwise, I will really have to buy my own router and go into modem mode, this hub is so slow in the GUI as well it's virtually impossible to change settings! I set a port forward and now it won't delete it!!! Horrible hub the older ones were better than the hub 3. So, does anyone please know where I can get a new hub/how to get a new hub that does Wi-Fi 6? Please don't suggest expensive kit as I am disabled and Starmer has literally cut my finances in half!  Thank you. Ruky. p.s - this is what my hub says.
If you still think something is wrong, please check the following
1Gateway IPv4 address is valid.
2Your broadband connection is working.
3Your broadband connection is ready.
4The temperature of your Hub 3.0 is normal.
5The status of telephone line 1 is not ready.
6The status of telephone line 2 is not ready.
7The device [REMOVED] has low signal strength, please move it closer to Hub 3.0.
8The device [REMOVED] has low signal strength, please move it closer to Hub 3.0.
9The device [REMOVED] has low signal strength, please move it closer to Hub 3.0.
10The device [REMOVED] has low signal strength, please move it closer to Hub 3.0.
11The device [REMOVED] has low signal strength, please move it closer to Hub 3.0.
12The device [REMOVED] has low signal strength, please move it closer to Hub 3.0.
13The device [REMOVED] has low signal strength, please move it closer to Hub 3.0.
14The device [REMOVED] has low signal strength, please move it closer to Hub 3.0.
15The device [REMOVED] has low signal strength, please move it closer to Hub 3.0.
16The device [REMOVED] has low signal strength, please move it closer to Hub 3.0.
17The device [REMOVED] has low signal strength, please move it closer to Hub 3.0.
18The device [REMOVED]has low signal strength, please move it closer to Hub 3.0.
19The device [REMOVED] has low signal strength, please move it closer to Hub 3.0.
20The device [REMOVED] has low signal strength, please move it closer to Hub 3.0.
21Please place your WiFi device near the Hub 3.0.
  • Hi Ruky,
    We're sorry to hear you're having some issues with your WiFi connection. A Hub 5 is only provided to those customers who are taking a 1GB connection speed, and don't already have a Hub 4.
    When having issues with your connection, the first thing to do is to have a look here. From that link, you'll be able to check if there's a fault in the area, test your line, replace your equipment or book an engineer visit if it's needed.
    There are so many things that can influence a WiFi connection some of which include but are not limited to, a fish tank being in the same room, walls being built with concrete instead of brick, it could even be that your next door neighbours router is interfering with yours. Due to this, we are only able to offer limited help. Please have a look here.
    The Hub's location could also be causing the coverage problem so we do need to check the positioning of it. Can you please ensure the following:
    • > Out in the open
    • > Next to the TV not behind it
    • > Away from large bodies of water (e.g. fish tanks)
    • > Away from baby monitors and cordless phones
    • > Away from microwaves
    Think of the Hub as a radio, and WiFi as the sound - the further away you are from the radio, or the more obstacles that are in the way (walls, electronic devices etc.), the quieter the radio & the poorer the WiFi.
    If that doesn't help, you can download our Connect App which will allow you to scan areas of your home and will offer help. If a WiFi Pod will help, the app will give you the option of adding this. You can view more information on that here.
    If after going through the self-checks, you still need some help, feel free to pop back to us so we can provide further help and support.
    Many thanks,
  • WiFi 6 works bests if you split the 2.4 & 5.0 into separate channels. Short range use 5.0, distance use 2.4. It is also useful for devices that need to use 2.4, as they cannot connect to a dual 2.4/5.0 stream, like my WiFi cameras.
    If you have WiFi issues it is best to run a Cat6 cable from your fastest port on your hub, to a central location, (stairs on a large property) and mount a router as a WiFi access point. Most modern Routers will self configure like this.
  • I was advised many years ago when I had a Hub2, to get my own router and set it up as a WiFi access point. When I moved into my current home a Bungalow, I ran cat5e cable via the Electrical ducting to all rooms. I could then have a WiFi access point whereever I wanted.
    Initially I used a 2nd hand Netgear Nighthawk R8000 for my WiFi. 2 Years ago I switched to a Tenda WiFi 6 Router. By using these I have never had a problem with WiFi.
  • Tudor's avatar
    You have a 350 connection so WiFi 6 will give you no increased speed to your devices. It’s all well and good wanting biggest-brightest-best just because it’s the one I’ve heard about and my devices support it, but if you want to have and use all the latest technology it’s cost money.
  • legacy1's avatar
    VM useless wifi yes look to get your own router with 1Gb ports and put hub in modem mode
    • rukhsanabd7's avatar
      rukhsanabd7
      Just joined
      thank you id like to say my connection is AWESOME! rock solid its just wifi thats a big let down, im going to attach a wifi 6 router made by Asus to my hub. thanks for your advice.
  • Hi Ruky,
    • > Out in the open
    Many thanks,
    Hub 3 is provided on connection up to M500 where Wi-Fi 5 / 802.11ac is fine.
    Coverage issues should be addressed by adding Wi-Fi access points / Wi-Fi Repeaters.
    Wi-Fi 6 on the Hub 5 has proved problematic with many IoTs.
      rukhsanabd7
      Just joined
      ok thanks i have m350 maybe im best just attaching my own router.
