Noobify's avatar
Noobify
Wifi goes down frequently - DHCP renew, No response T3 and ATOM self healing
Hi Experts,
I'm on Hub 3. Experiencing terrible wifi stability which disappears almost twice a day and comes back up once restarted The technician who visited couldn't resolve with usual cable check, replace with another Hub 3 splitter check etc. Here are the logs: - any solutions or advice ?
  • There is a hardware fault with the HUB, so putting it in modem mode probably won't resolve the issue.
  • Noobify's avatar
    Noobify
    1291000000336256 qam20
    21390000007.937256 qam1
    31470000007.137256 qam2
    41550000006.637256 qam3
    5163000000637256 qam4
    6171000000637256 qam5
    71790000005.637256 qam6
    81870000005.537256 qam7
    9195000000537256 qam8
    102030000004.536256 qam9
    11211000000436256 qam10
    122190000003.537256 qam11
    132270000003.536256 qam12
    142350000003.536256 qam13
    152430000002.536256 qam14
    16251000000236256 qam15
    17259000000236256 qam16
    182670000002.437256 qam17
    192750000002.536256 qam18
    202830000002.936256 qam19
    212990000003.536256 qam21
    223070000003.537256 qam22
    233150000003.537256 qam23
    243230000003.737256 qam24
    1Locked36.6530
    2Locked37.359192
    3Locked37.3610
    4Locked37.3840
    5Locked37.3750
    6Locked37.3490
    7Locked37.6610
    8Locked37.3590
    9Locked37.3450
    10Locked36.6660
    11Locked36.6690
    12Locked37.3660
    13Locked36.6520
    14Locked36.6790
    15Locked36.6770
    16Locked36.61200
    17Locked36.61010
    18Locked37.31080
    19Locked36.61040
    20Locked36.6560
    21Locked36.6680
    22Locked37.3520
    23Locked37.6630
    24Locked37.6830
  • Sephiroth's avatar
    Sephiroth
    The upstream power is fine, actually.  The power level from Hub is commanded by the VM end and is contingent on whether or not the VM end can read the keep-alive messages from the Hub.  In modem mode, the ATOM messages are unlikely to occur because the (wretched) Hub 3 has nothing to do other than act as a bridge to your router.
    The DHCP Renew messages are passive and you don’t need to worry about them.
    So, in terms of your experience, what is going wrong now?
