- NoobifyOn our wavelength
1 291000000 3 36 256 qam 20 2 139000000 7.9 37 256 qam 1 3 147000000 7.1 37 256 qam 2 4 155000000 6.6 37 256 qam 3 5 163000000 6 37 256 qam 4 6 171000000 6 37 256 qam 5 7 179000000 5.6 37 256 qam 6 8 187000000 5.5 37 256 qam 7 9 195000000 5 37 256 qam 8 10 203000000 4.5 36 256 qam 9 11 211000000 4 36 256 qam 10 12 219000000 3.5 37 256 qam 11 13 227000000 3.5 36 256 qam 12 14 235000000 3.5 36 256 qam 13 15 243000000 2.5 36 256 qam 14 16 251000000 2 36 256 qam 15 17 259000000 2 36 256 qam 16 18 267000000 2.4 37 256 qam 17 19 275000000 2.5 36 256 qam 18 20 283000000 2.9 36 256 qam 19 21 299000000 3.5 36 256 qam 21 22 307000000 3.5 37 256 qam 22 23 315000000 3.5 37 256 qam 23 24 323000000 3.7 37 256 qam 24 Downstream bonded channels
1 Locked 36.6 53 0 2 Locked 37.3 59 192 3 Locked 37.3 61 0 4 Locked 37.3 84 0 5 Locked 37.3 75 0 6 Locked 37.3 49 0 7 Locked 37.6 61 0 8 Locked 37.3 59 0 9 Locked 37.3 45 0 10 Locked 36.6 66 0 11 Locked 36.6 69 0 12 Locked 37.3 66 0 13 Locked 36.6 52 0 14 Locked 36.6 79 0 15 Locked 36.6 77 0 16 Locked 36.6 120 0 17 Locked 36.6 101 0 18 Locked 37.3 108 0 19 Locked 36.6 104 0 20 Locked 36.6 56 0 21 Locked 36.6 68 0 22 Locked 37.3 52 0 23 Locked 37.6 63 0 24 Locked 37.6 83 0 - SephirothAlessandro Volta
The upstream power is fine, actually. The power level from Hub is commanded by the VM end and is contingent on whether or not the VM end can read the keep-alive messages from the Hub. In modem mode, the ATOM messages are unlikely to occur because the (wretched) Hub 3 has nothing to do other than act as a bridge to your router.
The DHCP Renew messages are passive and you don’t need to worry about them.
So, in terms of your experience, what is going wrong now?
Thanks so much !
Related Content
- 4 months ago
- 2 years ago
