Jessie12356's avatar
Jessie12356
5 months ago
Wifi Booster Pod
Hi i need to order a wifi booster pod. I've tried going through the connect app but it says I have good signal all around my home but yet in the back bedroom I keep losing the signal to my wifi
  • Hey Jessie123456, thank you for reaching out and we are so sorry to hear you are struggling to order a WIFI pod.
    We will send you a DM to assist, they are free if you are on 1GB or a volt customer otherwise £8 per month.
  • I’ve had the same issue before  the app said my signal was “great,” but that one back room always dropped out. Turns out, those signal tests often measure average coverage, not dead spots caused by walls or interference. What helped me was manually checking Wi-Fi strength on my phone (using a signal analyzer app) and repositioning the router slightly closer to that room before buying extra hardware. Sometimes it’s not even the booster you need but smarter bandwidth management. I read a bit about how companies like Openvault help ISPs monitor and balance broadband traffic so sometimes the fix is on their end too, not yours.
