1 Reply
- Client62Alessandro Volta
Many IoTs have low cost Wi-Fi adapters and incomplete driver support, this is why they don't work with the Wi-Fi 6 service of the Hub 5.
Here are some practical options :
1) Run the Hub 5 in modem mode and add a decent Wi-Fi router that allows you to control what 802.11b/g/n/ax modes are operated on the 2.4GHz band. Make sure ax can be disabled.
2) Use a Wireless Repeater that outputs Wi-Fi 4 & Wi-Fi 5 as a bridge to the IoTs
( TP-Link RE450 AC1750 is been used by several customers and works with the Hub 5 in this role )
3) Add a basic Wireless Access Point just to support the 2.4GHz IoT ( these are inexpensive )
4) Replace the Hub 5 with a Hub 4 that has the more compatible 2.4GHz Wi-Fi 4 and 5GHz Wi-Fi 5
Related Content
- 6 months ago
- 5 months ago
- 1 year ago
