Jackmc89's avatar
Jackmc89
VM Ireland Hub 6 - Ubiquiti Network Help
Hey Folks,
I’d love to get some help. I have the latest router from Virgin, I think it’s called Hub 6. I have a network box with Ubiquiti Switch, and Dream Machine Pro. Issue is within the setting of the Hub, I can’t find a way to increase IP allocation or set to modem mode. One port off the switch is working fine for my TV, but when I connect a Ethernet cable into port 2 of my switch and into my Sky Stream puck I get an error that IP allocation isn’t working. Any ideas what settings I need to change on the hub? As I will be installing multiple access points and cameras on the house
