Bigslippers's avatar
Bigslippers
VM Connect can't find Hub 4
Another one for the VM Connect not finding Hub 4.
No VPN, yes on VM Wifi, yes it is working, yes I can see Hub4 via IP.
Trying to connect to scan to get a first pod as bedroom speeds are 12 and below.
Help or shortcut to Pod from VM support via forum would be great - I won't be phoning support unless VM are going to refund the time spent on the phone from my monthly bill and I'm not sure you'd want to pay my hourly rates.
    • Bigslippers's avatar
      Bigslippers
      Trying to confirm if a weak signal is the reason it drops out in the bedrooms - app should help find that and if it is then a pod should resolve. Net result probably yes, I need a pod
      • Vikki_M's avatar
        Vikki_M
        Hi Bigslippers
        We're sorry to hear the connect app isn't finding your hub.
        Please try clearing the data within the Connect App. These steps will help you do that:
        For your Apple device, you can try this: Open Settings > Tap your name > Tap iCloud > Tap Manage Settings > Tap the Connect App > Tap Delete Data.
        For your Android device, you can try this: Open settings > Apps > Connect App > Storage > Clear data / Clear cache.
        Please pop back to us when you can.
    Seeing the Hub 4 via IP is a start..
    But can you login in at http://192.168.0.1/   ?
    Once the Hub 4 password is entered do you have a working admin menu or just a blank screen i.e. the classic Hub 4 Router mode admin menu death syndrome with both Connect App and any VM Pods failing to function.
      Bigslippers
      Access via IP works - its just a rubbish user experience. I'm trying to get a pod but no obvious route without the Connect app working
  • p.s. have tried on 2.4 and 5 - no joy. Latest firmware on Hub 4 and latest version of VM Connect. Cache etc cleared, app reinstalled, forum scoured and no consumer solution.
