mickb1960's avatar
mickb1960
6 months ago
Use own Hub
Any advice on using my own hub instead of my VM Hub 4 would be helpful. The reason if that I can not use my Blink Camera's with the Hub 4 even with the 5Ghz wi fi signal disabled. The Hub would need to be 2.4 Ghz only.
1 Reply
  • goslow's avatar
    goslow
    VM will only allow you to use equipment that VM supplies to connect to the VM network.
    You can, however, put the VM hub into modem mode and use your own wireless networking equipment.
    Have you looked through some of the past Blink topics on here? Some claim to have got cameras connected with a variety of procedures/resets/switch on sequences.
