Neilk84's avatar
Neilk84
12 months ago
Unstable Connection
Hi All
Ive just had broadband installed 1 gig with hub 5. Getting great speeds, but everytime i run a speed test on the Ookla speedtest app. Before i start it. The circle shows in yellow and says my internet connection may be unstable. Ive never experienced this before, as it is usually green and good to go. Ive tried power cycling everything, and even factory resetting hub, this hasnt changed anything. Ive tried this on other providers and even family memebers virgin broandband, no of them show this warning. Just my connection. I have FTTP.
Also i am waiting on my first wifi pod that has never arrived after over a week of waiting, after being told it would be with me in 72 hours.
All help appreciated
  • Has anyone got an answer to this as I’m getting the same thing and have done since virgin was installed
  • Hi, I am having the same issue.  Just had Virgin's FTTP broadband installed 1 gig with hub 5, but when I run a speed test on the Ookla speedtest app, it says my internet connection may be unstable.  I am not getting this when I run the speedtest at work or on friends.
    Any help would be greatly appreciated.
    • John_GS's avatar
      John_GS
      Hello Mandy70
      Thanks for posting. What speeds are you getting on the app and via wired connection please?
  • Anonymous's avatar
    Anonymous
    Did you ever get to the bottom of this?
    • Neilk84's avatar
      Neilk84
      it sorted itself out not long after i posted this. im guessing someone looked into it.
        Anonymous
        Weird. Mine does it some days, not others. Thanks for getting back to me.
    Which Hub do you have exactly? The Hub 5 or Hub 5X ?  For XGS-PON fibre it will be the 5X
    • Neilk84's avatar
      Neilk84
      Its the 5. Fibre comes into my house to a small white box, then coaxout from that to the hub 5
      • Matthew_ML's avatar
        Matthew_ML
        Hey Neilk84, thank you for reaching out and I am so sorry to hear this.
        I can see you are currently in a DM with my colleague, please do reach out if you need some assistance still.
