Abbasali's avatar
Abbasali
11 months ago
Troubleshooting Wireless Port Issues
Dear All,
Currently I am facing an issue with connectivity and ports issues with my broadband, especially for applications that mandate certain ports to be open. While trying to troubleshoot this issue, I found a port diagnostics tool PortChecker.dev which was really helpful.
PortChecker.dev is particularly useful for users having problems with port forwarding, port blocking, or obsevring whether a specific port is open for their broadband. The website is user-friendly, as no additional software installation is required in order to test the ports.
This is how it works:
You simply enter the wanted port you want to check, for example, port 80, 443, or any custom port.
The system will determine if the port is open, closed, or filtered, helping to diagnose network based problems.
For anyone dealing with online gaming, server hosting, or even troubleshooting broadband connectivity issues, it’s a perfect tool.
If you are facing any of the above network trouble, make sure to check this out! For further information, just go to PortChecker.dev.
If any of you have used similar tools or have any tips to boost broadband and wireless networks, please do share!
