Branders's avatar
Branders
Tapo smart Wifi bulb not connecting.
I've recently bought a Tapo L535E smart WiFi bulb which isn't connecting to our Hub4.
I've tried disabling the 5GHz mode and even trying a temporary unrestricted guest WiFi with no luck.
Rebooting the hub and the bulb hasn't given any success either.
I've noticed a few similar posts but short of a new hub I've not seen any resolutions.
  • Hello, I'm new to virgin 10 days). The engineer connected my TV without issues.  As i set about to connect other things to the router I discovered that none of my tapo would connect.  I have reset the hub, deleted all devices but I'm having no joy (hub, doorbell. Plugs and cameras)  I'm not 'tecky' so I struggle.  I have tried to contact virgin directly but without a reply as yet.  Any help would be greatly appreciated.
    Hub 5 may well be far worse, there are many reports of IoT not working.
    It is hard to know what to suggest to folks that don't include ( i.e link to ) the install process they are following and don't include any screen shots / error messages when things go wrong. For all we know the bulb is still in the box !
  • Unfortunately I don't find the option of buying an additional router to be a resolution of the problem.
    I'd just replace the bulb or buy a hub for it as it'd be cheaper - I'm hoping to find a resolution for any settings missed or if a replacement hub 5 is the only way for the actual provided hubs to function.
  • legacy1's avatar
    WoW I must not be trying enough you need to get your own router with 1Gb ports and put hub in modem mode.
