Eggytel's avatar
Eggytel
Tado not working on HUB 5
I am having the exact same issue as some other posts on here. Having switched to VM recently. Having switched to VM recently. My heating system which is less than a year old no longer working due to not being able to connect to the internet..Luckily I found an old wifi extender with an ethernet port that does appear to do the job but it is temperamental. I really don't see why a customer should be spending more money to provide a bodge when an IP's HUB should have at least one port capable of some backward compatibility or a means to provide this supplied by the IP. VM support links always appear to send me back to a post on here without any clear answers from their own technical support, rather opinions of what might work from (what I am sure are very knowledgeable) fellow customers. I have posted on the end of that post and appreciate advice from others regarding the use of a 10/100 switch ...however direct help from VM is sought for which I have been advised to start a new thread!
Seems barmy to me that this is how you seek technical advice beyond the self diagnosis tool which factory resets the HUB, and yes already tried and failed.
  • Update to thread is that as per suggestions from other members I opted for an additional switch unit ( 10/100Mbps Ethernet Switch was search in Amazon/Google) this cost less than £10 and does require extra power source. It has now been in place 1 week and I have had no drop off in service allowing heating to work. Thanks again to those offering advice.
    My issue is still the lack of built in backwards compatibility especially for what must be a very common set up and the lack of information directly from VM to help other than via this forum.
    I hope however that anyone with a similar issue can use this thread to solve the issue relatively quickly.
  • Tudor's avatar
    Unfortunately I do not think you will get a definitive answer from VM. It has been proved by others that the Hub5 only has ports that support 100/1000, not 10/100/1000. Also VM have never published the technical specifications of any of their hubs. My suggestion is to buy a cheap 5 port network switch about £10 to £15, but do not use it on port 4 the 2.5G one. That’s another story.
    • JakeyyB's avatar
      JakeyyB
      My router only had 4 2.5g ports (different brand). Do you know what switch I'll need for that as having the same tado issue?
      • Tudor's avatar
        2.5 ports are multi, so 100/1000 should definitely work
    If VM replaced the Hub 5 with a Hub 3 or Hub 4 would that make the OP content ?
  • Thanks Client62 for your support on other thread and Tudor here I understand that this appears to be the route to take...the issue is being able to get an answer from VM regarding the equipment they supply!
    The lack of compatibility with what is still a relatively common interface ... Yes TADO could/should also be held to account as they are using an older system in the assumption that backward compatibility is available!
    • Lee_R's avatar
      Lee_R
      Hi Eggytel  thanks for getting back to us.
      Sorry to hear you're unhappy with our hub 5 and compatibility issues.  Can you please confirm what you're looking to be your next steps?  As I can see you've been given advice from our fantastic fellow community members.
      Lee
      • ToemasSanti's avatar
        ToemasSanti
        Did you get any answers to this? Since joining in Feb, I’ve had nothing but issues. Mainly this situation with Ethernet ports not working or getting ridiculously high ping/latency when they do.
        any help appreciated.
  • legacy1's avatar
    Might as well get a better router and use hub in modem mode
    • Nreyno's avatar
      Nreyno
      Hey, hope its OK to jump on this thread, we've been without heating now for 48hrs trying to connect this Tado bridge.
      I've added a TP link 10/100 and it won't connect, I'm now trying to connect it via the laptop shared Internet access which isn't working. Tado say the following;
       set the DNS settings of your router to the Google DNS:
      Primary DNS Server: 8.8.8.8
      Secondary DNS Server: 8.8.4.4
      tado° uses port 443 TCP
      Reserve an IP address for the Internet Bridge in the DHCP settings of your router.
      If you do not know how to set the DNS settings or the IP address, please consult your router manual or contact your internet provider
      How on earth do I do that?? I can't see anywhere on the apps how we can adjust the settings. I'm simply at a loss on what else to do. SOMEONE PLEASE HELP!
        You can’t change the DNS settings on any VM Hub.
    The tired and found to be working approach is :
    Tado bridge ------   TP link ( or similar ) 10/100 network switch  ------ a 1GB/s port of a VM Hub 5 or Hub 5x
    None of the DNS or other Port settings are needed.
  • I had this issue and used a TP link network adapter,connected from port1 on router to port 1 on the network adapter, then plugged the bridge into port 3. Connected straight away.
    If I was buying a switch I'd pick a 10/100/1000 they are low in cost and more useful.
    If I had a 10/100 switch spare, I'd put that into service ASAP to get the heating system working again,
    note some folks also reported success with 10/100 Powerline adaptors, i.e. try with whatever is to hand.
    • durrant23's avatar
      durrant23
      Settling in
      I purchased a 10/100 TP switch (https://amzn.eu/d/7BBp0St) and it didn’t work unfortunately. Tried all port combinations and the bridge still shows a blinking router light.
      Would  purchasing the gigabit version of the switch make any difference? Eg https://amzn.eu/d/ahZXP0p   I can’t see how it would and I’m reluctant to invest in more purchases unless I know they’ll work.
       At my wit’s end with this thing now. VM and Tado both absolving themselves of responsibility.
      • carl_pearce's avatar
        carl_pearce
        Superstar
        I think the main point is you need a switch / router capable of 10Mbps, which the HUB 5 is either not, or not very good at.
        So, any switch that supports 10Mbps, even the gigabit type, should be ok, however, the HUB needs to play 'nice' with it also, which is the challenge.
  • This worked for me: Wifi extender with a Ethernet port (another tado suggestion) - they can work in reverse - latch onto wifi and feed a network over cat cable to your tado internet bridge (the one I chose TP-Link TL-WA850RE N300Mbps). For £15 -   It also worked (I could net get 10/100 switches to work)
