bw2020's avatar
bw2020
Solid RED light on hub3
Like many other posters, I have had a solid orange light on my hub 3 but this has now changed to a solid red light. As I understand, this needs attention, I cannot live without my internet.
I have tried the pinhole reset and the off/on reset, all to no avail. Virgin have also tried a remote reset which failed after 2 mins.
Hub feels hot to the touch.
Need some help here Virgin, please.
bw2020
  • Zach_R's avatar
    Zach_R
    Hi bw2020,
    Thank you for your post and welcome back to our community forums. We're here to help.
    I'm sorry to hear of your router issues and that it's now displaying a constant red light. If you haven't done so already, please follow each of these steps to try and remedy this.
    • Then use the power switch to turn the unit back on. The Hub should now operate normally.
    If the issue remains after following the above, please respond to the private message that I'll be sending to you shortly and we can assist you from there.
    • bw2020's avatar
      bw2020
      Hello Zak
      Done all that many times, no effect, tried both the on/off switch and the pinhole reset. Virgin remotely tried to do the 20 min factory reset and this failed after 2 mins.
      Bob
