Aaronwolfy's avatar
Aaronwolfy
Slow ethernet speed
Got the gig 1 package with the virgin hub 5, get around 800 mbps over wifi so all is well there but on my desktop I can manage at best 330mbps, I've went through guides everywhere, putting on latest drivers, putting on basic drivers, changing mtu sizes and settings for 1gb duplex etc, my desktop is on a 1300mps powerline adapter from tp link, I've tried the desktop plugged straight in to the router too to rule out the powerline adapter being at fault despite the poweline adapter telling me it's got a connection of over 900mps between, tried my laptop and on the WiFi that can hit around 700 but on ethernet it can also only reach 320 mbps, I've tried every port on the hub 5, I have installed windows 11 and I am still not getting any better than 320mbps, so unless every ethernet port on the hub 5 is faulty I am at a loss as what to do
  • goslow's avatar
    goslow
    Any testing you do should be with the device connected direct to the VM hub.
    What specification is the network cable you are using to connect with? Have you tried a different network cable from device to hub?
    If you start the device in safe mode with networking do you get any different/better speed?
    When you are testing, have you disabled any onboard wireless adapters on your devices so you are definitely testing via ethernet only?
    Do you have any VPN connections off when testing?
    • Aaronwolfy's avatar
      Aaronwolfy
      Done all that and have used cate 5e, cat 6 and a new cat 8 cable, has been tested with out any wifi adapters and pure ethernet only
      • goslow's avatar
        goslow
        And you got the same results in safe mode with networking?
  • legacy1's avatar
    test with Edge
     powerline adapters will limit you
      Aaronwolfy
      Tried with chrome, mozzilla, edge and steam, all consistant
    330Mb/s over a TP-Link Powerline adaptor is quite decent.
    AV1300 does not imply 1300Mb/s of throughput, the reality is throughput will be barely 1/3 of the actual link rate.
    Use the TP-LINK Utility program to see the link rate, then divide by 3 to get a rough guide of what may be expected as bandwidth at the PC.
    Reversing my figures, the link rate could be around 900, which is excellent for an AV1300 device that has to work on ring circuit power lines with noise from TVs, PCs, mobile chargers, laundry equipment etc etc.
      Aaronwolfy
      It is a decent powerline adapter and the circuitry is good in this house, the app for the powerline adapter says its connection between the two is around 900 which is what I expected, I wouldn't mind at all if I was getting at least 700mbps but maxing out at 320 is bothering me
      • goslow's avatar
        goslow
        You have said though that you only get the 300-ish Mbps when you are connected direct to the hub so the powerline speed is a bit irrelevant at this point if the speed connected direct to the hub is only 320 Mbps via ethernet.
    700 * 3 = 2100.
    Can you buy a Powerline adaptor to link at that rate in a real home ?
    I do not think so
  • I have taken the pc directly to the hub and tried the cables I have on hand, a cat5e, cat6 and a new cat 8 and the results are the same, my laptop which does have gigabit also pulls the same speed on ethernet but is able to get 913mbps on the wifi, it's like all the ethernet ports on the hub 5 are locked down too 320mbps
    • Ashleigh_C's avatar
      Ashleigh_C
      Hi there Aaronwolfy
      Thank you so much for your post and welcome to the community forums, it's great to have you.
      I am so sorry that you have faced an issue with your connection and a big thank you to our community for their help so far.
      I have checked this on our side and I cannot see any issues that may be causing this.
      Can you post your Hub status and logs? How to do this;
      • Copy/paste the data from each of the tabs as text into a 'REPLY' as opposed to 'QUICK REPLY'. Please do not include your MAC address.
      Also, set up a 'Broadband Quality Monitor'. This will monitor the state of your connection and record any network dropouts etc
      Give it a while to gather data and then click 'Share Live graph' and paste the 'Direct Link' into the forum
        Aaronwolfy
        Cable Modem Status
        Item Status Type
        Cable Modem Status Online DOCSIS 3.0
        Primary downstream channel Locked SC-QAM
        Channel Overview Downstream Upstream
        DOCSIS 3.0 channels 32 5
        DOCSIS 3.1 channels 1 1
        3.0 Downstream channels
        1 331000000 6.7 39 QAM 256 25
        2 139000000 7.9 39 QAM 256 1
        3 147000000 7.6 39 QAM 256 2
        4 155000000 7.5 39 QAM 256 3
        5 163000000 7.5 39 QAM 256 4
        6 171000000 7.4 39 QAM 256 5
        7 179000000 7.3 39 QAM 256 6
        8 187000000 7.1 39 QAM 256 7
        9 195000000 7.3 39 QAM 256 8
        10 203000000 7.1 39 QAM 256 9
        11 211000000 7.2 39 QAM 256 10
        12 219000000 7.2 39 QAM 256 11
        13 227000000 7 39 QAM 256 12
        14 235000000 6.9 39 QAM 256 13
        15 243000000 6.8 39 QAM 256 14
        16 251000000 6.3 39 QAM 256 15
        17 259000000 5.8 39 QAM 256 16
        18 267000000 5.8 39 QAM 256 17
        19 291000000 6.4 39 QAM 256 20
        20 299000000 6.5 39 QAM 256 21
        21 323000000 6.8 39 QAM 256 24
        22 355000000 7.8 40 QAM 256 28
        23 363000000 8.2 40 QAM 256 29
        24 387000000 8.6 40 QAM 256 32
        25 395000000 8.4 40 QAM 256 33
        26 403000000 8.1 40 QAM 256 34
        27 411000000 7.7 40 QAM 256 35
        28 419000000 7.4 40 QAM 256 36
        29 427000000 7.2 40 QAM 256 37
        30 435000000 6.6 39 QAM 256 38
        31 443000000 6 39 QAM 256 39
        32 451000000 6.1 39 QAM 256 40
        1 Locked 39 4 0
        2 Locked 39 8 0
        3 Locked 39 5 0
        4 Locked 39 5 0
        5 Locked 39 5 0
        6 Locked 39 3 0
        7 Locked 39 3 0
        8 Locked 39 4 0
        9 Locked 39 4 0
        10 Locked 39 11 0
        11 Locked 39 5 0
        12 Locked 39 20 0
        13 Locked 39 24 0
        14 Locked 39 8 0
        15 Locked 39 5 0
        16 Locked 39 8 0
        17 Locked 39 5 0
        18 Locked 39 10 0
        19 Locked 39 7 0
        20 Locked 39 4 0
        21 Locked 39 3 0
        22 Locked 40 8 0
        23 Locked 40 6 0
        24 Locked 40 9 0
        25 Locked 40 6 0
        26 Locked 40 6 0
        27 Locked 40 5 0
        28 Locked 40 6 0
        29 Locked 40 5 0
        30 Locked 39 9 0
        31 Locked 39 1 0
        32 Locked 39 17 0
        3.1 Downstream channels
        159 94 4K 1840 QAM 4096 1108
        159 Locked 37 4.5 701732893 7
        3.0 Upstream channels
        0 49600000 43 5120 QAM 64 1
        1 43100000 43.3 5120 QAM 64 2
        2 36600000 44 5120 QAM 64 3
        3 30100000 43.8 5120 QAM 64 4
        4 23600000 43.5 5120 QAM 64 5
        0 ATDMA 0 0 0 0
        1 ATDMA 0 0 0 0
        2 ATDMA 0 0 0 0
        3 ATDMA 0 0 3 0
        4 ATDMA 0 0 0 0
        3.1 Upstream channels
        6 10 36.2 2K QAM 256
        6 OFDMA 200 74000000 0 0
        General Configuration
        Network access Allowed
        Maximum Number of CPEs 1
        Baseline Privacy Enabled
        DOCSIS Mode 3.1
        Config file 4k;fg87dsfd;kfoA,.iyewrkl
        SFID 5534
        Max Traffic Rate 1200000450 bps
        Max Traffic Burst 42600bytes
        Min Traffic Rate 0 bps
        Primary Upstream Service Flow
        SFID 5525
        Max Traffic Rate 110000274 bps
        Max Concatenated Burst 42600bytes
        Scheduling Type Best Effort
