archercj
1 year agoFibre optic
Should I utilise a Hub5 or continue with my current setup
I currently have a Hub4 in modem mode and connected to that an Asus ZenWifi CT8 mesh system. From this I have several CCTV cameras, 2 x Xbox, a Windows server and several other devices (about 25 in total). I use fixed IP's, port forwarding etc.
I am getting a Hub5 shortly. The main benefit over my current setup is Wifi6 (the Asus CT8 only support Wifi5). Is it worth ditching the Asus and utilising the Hub5?
And if so what extender would people recommend as I know I will need it due to device locations (bottom of the garden).
Or maybe use the WiFi6 of the Hub5 on a separate wifi network with a different IP range?
Any advice greatly received.
