lojelo5's avatar
lojelo5
Superfast
Seeing way too many errors
I have been seeing quite a lot of Pre & Post errors this last few weeks I only cleared this yesterday
3.0 Downstream channels
Channel	Frequency (Hz)	Power (dBmV)	SNR (dB)	Modulation	Channel ID
1	331000000	6.7	41	QAM 256	25
2	139000000	9.4	42	QAM 256	1
3	147000000	9.3	42	QAM 256	2
4	155000000	9.2	42	QAM 256	3
5	163000000	9.1	42	QAM 256	4
6	171000000	8.9	42	QAM 256	5
7	179000000	8.7	42	QAM 256	6
8	187000000	8.8	42	QAM 256	7
9	195000000	9	42	QAM 256	8
10	203000000	8.9	42	QAM 256	9
11	211000000	8.8	42	QAM 256	10
12	219000000	8.4	42	QAM 256	11
13	227000000	8.1	42	QAM 256	12
14	235000000	7.8	42	QAM 256	13
15	243000000	7.3	42	QAM 256	14
16	251000000	6.8	42	QAM 256	15
17	259000000	7	42	QAM 256	16
18	267000000	7.3	42	QAM 256	17
19	291000000	7.7	42	QAM 256	20
20	299000000	7.5	42	QAM 256	21
21	307000000	7.3	42	QAM 256	22
22	315000000	6.9	42	QAM 256	23
23	323000000	6.7	41	QAM 256	24
24	339000000	7	41	QAM 256	26
25	347000000	7.2	42	QAM 256	27
26	355000000	7.1	42	QAM 256	28
27	363000000	7	42	QAM 256	29
28	371000000	7	42	QAM 256	30
29	379000000	6.5	42	QAM 256	31
30	387000000	5.8	42	QAM 256	32
31	491000000	5.5	42	QAM 256	33
32	499000000	5.4	42	QAM 256	34
Channel	Locked Status	RxMER (dB)	Pre RS Errors	Post RS Errors
1	Locked	41	18422	3780
2	Locked	42	5	962
3	Locked	42	1	1021
4	Locked	42	7366	552
5	Locked	42	7329	890
6	Locked	42	2	0
7	Locked	42	5069	41
8	Locked	42	4892	40
9	Locked	42	3289	26
10	Locked	42	4193	42
11	Locked	42	1663	49
12	Locked	42	1	0
13	Locked	42	9	0
14	Locked	42	6	0
15	Locked	42	3	0
16	Locked	42	5	0
17	Locked	42	7	0
18	Locked	42	8	0
19	Locked	42	10	0
20	Locked	42	9	0
21	Locked	42	6	0
22	Locked	42	11	0
23	Locked	41	11	0
24	Locked	41	9	0
25	Locked	42	11	0
26	Locked	42	4	0
27	Locked	42	8	0
28	Locked	42	6	0
29	Locked	42	10	0
30	Locked	42	7	0
31	Locked	42	10	0
32	Locked	42	9	0
3.1 Downstream channels
Channel	Channel Width (MHz)	FFT Type	Number of Active Subcarriers	Modulation (Active Profile)	First Active Subcarrier (Hz)
159	94	4K	1840	QAM 4096	1108
Channel ID	Locked Status	RxMER Data (dB)	PLC Power (dBmV)	Corrected errors (Active Profile)	Uncorrectable errors (Active Profile)
159	Locked	43	2.8	1749929165	0
3.0 Upstream channels
Channel	Frequency (Hz)	Power (dBmV)	Symbol Rate (ksps)	Modulation	Channel ID
0	49600000	47.3	5120	QAM 64	1
1	43100000	46.8	5120	QAM 64	2
2	36600000	46.3	5120	QAM 64	3
3	30100000	45.8	5120	QAM 64	4
4	23600000	45.3	5120	QAM 64	5
Channel	Channel Type	T1 Timeouts	T2 Timeouts	T3 Timeouts	T4 Timeouts
0	ATDMA	0	0	3	0
1	ATDMA	0	0	1	0
2	ATDMA	0	0	0	0
3	ATDMA	0	0	2	0
4	ATDMA	0	0	8	0
3.1 Upstream channels
Channel	Channel Width (MHz)	Power (dBmV)	FFT Type	Modulation
6	10	41.2	2K	QAM 256
Channel	Channel Type	Number of Active Subcarriers	First Active Subcarrier (Hz)	T3 Timeouts	T4 Timeouts
6	OFDMA	200	74000000	0	0
Time	Priority	Description
13-05-2024 21:52:00	notice	US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-05-2024 21:52:00	warning	DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-05-2024 20:11:12	notice	US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-05-2024 20:11:12	warning	DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-05-2024 20:01:06	notice	US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-05-2024 20:01:06	warning	DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-05-2024 18:53:45	notice	CM-STATUS message sent. Event Type Code: 4; Chan ID: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 20 21 22 23 24 26 27 28 29 30 31 32 33 34 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS
13-05-2024 18:53:45	notice	CM-STATUS message sent. Event Type Code: 22; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-05-2024 18:53:45	notice	CM-STATUS message sent. Event Type Code: 5; Chan ID: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 20 21 22 23 24 26 27 28 29 30 31 32 33 34; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1
13-05-2024 18:53:45	notice	CM-STATUS message sent. Event Type Code: 23; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-05-2024 18:53:45	notice	CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-05-2024 18:53:13	critical	No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-05-2024 18:53:11	warning	DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-05-2024 18:53:10	critical	Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-05-2024 18:53:01	critical	SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-05-2024 18:53:00	warning	MDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-05-2024 18:52:57	critical	SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-05-2024 10:26:24	warning	DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-05-2024 10:26:24	notice	US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-05-2024 10:16:17	warning	DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-05-2024 10:16:17	notice	US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-05-2024 10:06:13	notice	US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-05-2024 10:06:13	warning	DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-05-2024 09:45:58	notice	US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-05-2024 09:45:58	warning	DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-05-2024 09:35:54	warning	DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-05-2024 09:35:54	notice	US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-05-2024 08:35:31	notice	US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-05-2024 08:35:31	warning	DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-05-2024 08:25:21	notice	US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-05-2024 08:25:21	warning	DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
13-05-2024 05:54:00	warning	DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
  • RT123's avatar
    RT123
    Up to speed
    Appreciate that there’s a lot of PostRS errors (which are the ones to be concerned about) - the sync failures are also concerning.
    Can you repost the stats to confirm if the PostRS errors are still rising please - just so that the forum team can see that.
  • I've had a BQM set up for ages but it doesn't seem too bad
    Errors are exactly the same as yesterday but will keep an eye on it and see if they rise anymore.
    • lojelo5's avatar
      lojelo5
      Superfast
      Well I start this topic and the day after I get an email telling me there is work being done in my area tomorrow.
      • Carley_S's avatar
        Carley_S
        Hi lojelo5
        Welcome back to the community forums
        Sorry to hear of your service concerns. How are things now in your area? Are the works still ongoing or have the been completed since you posted on Wednesday?
        Keep us updated if the works are completed and you're still experiencing any issues and we'll assist further if needed.
  • Sabrina_B's avatar
    Sabrina_B
    Hi lojelo5 👋.
    Thanks for reaching out to us, apologies for the issues that you are having with your service, you will have a log of many errors and what cannot be seen is that most Pre will be corrected once reaching the hub and the internet being delivered to yourself. Can I ask, since your post, what is the current state of service you are in receipt of?
    Please let us know.
    Sabrina
    • lojelo5's avatar
      lojelo5
      Superfast
      I have still been monitoring this and once again seeing way too many errors.
      1	331000000	7.1	41	QAM 256	25
      2	139000000	9.6	42	QAM 256	1
      3	147000000	9.5	42	QAM 256	2
      4	155000000	9.4	41	QAM 256	3
      5	163000000	9.2	42	QAM 256	4
      6	171000000	9	42	QAM 256	5
      7	179000000	8.9	42	QAM 256	6
      8	187000000	8.9	42	QAM 256	7
      9	195000000	9.2	42	QAM 256	8
      10	203000000	9.1	42	QAM 256	9
      11	211000000	8.9	42	QAM 256	10
      12	219000000	8.5	42	QAM 256	11
      13	227000000	8.3	42	QAM 256	12
      14	235000000	8	42	QAM 256	13
      15	243000000	7.6	41	QAM 256	14
      16	251000000	7.1	41	QAM 256	15
      17	259000000	7.1	41	QAM 256	16
      18	267000000	7.4	42	QAM 256	17
      19	275000000	7.5	42	QAM 256	18
      20	283000000	7.8	42	QAM 256	19
      21	291000000	7.9	42	QAM 256	20
      22	299000000	7.7	42	QAM 256	21
      23	307000000	7.5	42	QAM 256	22
      24	315000000	7.2	42	QAM 256	23
      25	323000000	7	41	QAM 256	24
      26	339000000	7.3	41	QAM 256	26
      27	347000000	7.5	42	QAM 256	27
      28	355000000	7.4	42	QAM 256	28
      29	363000000	7.3	42	QAM 256	29
      30	371000000	7.4	42	QAM 256	30
      31	379000000	7.1	42	QAM 256	31
      32	387000000	6.4	42	QAM 256	32
      1	Locked	41	17679	1564
      2	Locked	42	7792	294
      3	Locked	42	6894	48
      4	Locked	41	7342	59
      5	Locked	42	6267	54
      6	Locked	42	5548	36
      7	Locked	42	3460	36
      8	Locked	42	2590	71
      9	Locked	42	2018	35
      10	Locked	42	2	0
      11	Locked	42	3	0
      12	Locked	42	2	0
      13	Locked	42	1	0
      14	Locked	42	5	0
      15	Locked	41	5	0
      16	Locked	41	7	0
      17	Locked	41	5	0
      18	Locked	42	7	0
      19	Locked	42	6	0
      20	Locked	42	6	0
      21	Locked	42	3	0
      22	Locked	42	6	0
      23	Locked	42	4	0
      24	Locked	42	17	0
      25	Locked	41	6	0
      26	Locked	41	15	0
      27	Locked	42	10	0
      28	Locked	42	9	0
      29	Locked	42	14	0
      30	Locked	42	6	0
      31	Locked	42	7	0
      32	Locked	42	16	0
      159	Locked	43	3.5	83704662	0
      09-06-2024 22:18:04	notice	US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      09-06-2024 22:18:04	warning	DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      07-06-2024 10:14:51	notice	CM-STATUS message sent. Event Type Code: 5; Chan ID: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 26 27 28 29 30 31 32; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1
      07-06-2024 10:14:51	notice	CM-STATUS message sent. Event Type Code: 4; Chan ID: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 26 27 28 29 30 31 32 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS
      07-06-2024 10:14:51	notice	CM-STATUS message sent. Event Type Code: 24; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: 0 1 2 3.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      07-06-2024 10:14:51	notice	CM-STATUS message sent. Event Type Code: 23; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      07-06-2024 10:14:51	notice	CM-STATUS message sent. Event Type Code: 22; Chan ID: 159; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      07-06-2024 10:14:12	warning	DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      07-06-2024 10:14:12	critical	No Ranging Response received - T3 time-out;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      07-06-2024 10:14:03	critical	SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      07-06-2024 10:14:03	warning	MDD message timeout;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      07-06-2024 10:13:59	critical	SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      06-06-2024 18:19:36	error	DHCP RENEW WARNING - Field invalid in response v4 option;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      04-06-2024 21:37:36	notice	US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      04-06-2024 21:37:36	warning	DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      04-06-2024 21:07:24	notice	US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      04-06-2024 21:07:24	warning	DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      04-06-2024 20:16:59	warning	DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      04-06-2024 20:16:59	notice	US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      04-06-2024 20:06:51	notice	US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      04-06-2024 20:06:51	warning	DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      04-06-2024 19:46:46	notice	US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      04-06-2024 19:46:46	warning	DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      04-06-2024 19:36:41	notice	US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      04-06-2024 19:36:41	warning	DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      04-06-2024 19:16:26	warning	DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      04-06-2024 19:16:26	notice	US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      04-06-2024 19:06:23	notice	US profile assignment change. US Chan ID: 6; Previous Profile: 11 13; New Profile: 12 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      04-06-2024 19:06:23	warning	DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      04-06-2024 01:07:11	notice	US profile assignment change. US Chan ID: 6; Previous Profile: 12 13; New Profile: 11 13.;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      04-06-2024 01:07:11	warning	DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
      04-06-2024 00:57:04	warning	DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value;CM-MAC=**:**:**:**:**:**;CMTS-MAC=**:**:**:**:**:**;CM-QOS=1.1;CM-VER=3.1;
